Have a question? Ask Woody!
MDF joinery question
wilbur
>This just occurred to me:
Does MDF have a grain orientation, as in long grain and end grain? My guess is no, based on what I know of how MDF is made, but I could be wrong.
If there isn't a grain orientation to MDF, does this mean that MDF butt joints have the same strength as gluing two pieces of MDF face to face with the same area?
Re: MDF joinery question
Thomas S Stockton
>Mdf does not have a grain orientation, certain types will vary in density from the outside in.
Buttjoints in MDF really are not that strong. It would be best to describe what you're wanting to do and answer questions from there
Tom
Brian in Sandusky, OH
>Use confirmat screws when joining MDF.
Confirmat screws have longer, sharper threads, and are made specifically for MDF and particle board.
Always a lot stronger than standard wood screws.
Now if you're making a shop jig, or something that is not exactly fine furniture, glue and standard screws will probably be fine...but if you are doing something where you want to make sure, use confirmat screws.
wilbur
>I'm actually not planning an MDF project right now. I was thinking about ways to join solid wood end-to end to lengthen a board, and that's when I thought that MDF in such an application would be easier to deal with. My question was more of a thought experiment.
Yonak
>The grain is not oriented in the X or Y dimension, but is oriented at right angles to the Z dimension. If you drop it on a corner, you will see that it flakes like a sandwich. ..At least that's true in Ultralight MDF and I assume it's true in regular MDF.
Thomas S Stockton
>End to end even with joinery would be weak. MDF is made in longer than 8' lengths so that is a possibility.
Tom
