Re: 3.4in Plywood
Jim Dillon
>Jason,
While your quest for the perfect fit is laudable, keep in mind that your piece of plywood may vary just a bit in thickness along its length and width - especially near uncut edges. Maybe it is a moisture thing or something. If I can afford the loss in wood, I usually cut an inch (couple of centimeters) off the edge and go from there. And a longer piece of plywood may be bent a bit making the fit all along the "perfect" dado more troublesome. On the other hand, if you are just cutting dadoes for bookshelves etc, then the 23/32 inch bit mentioned by others may be what you need, but I've never had much luck with it; it ends up being too small or too big. Using good quality plywood will also make your job easier. Just some thoughts. Good luck.
Jim
