Veritas - Innovation in Tools
Wood entry door finish questions *LINK*
Grant Smith
>Hi all,
My lovely wife and I are building a home and one of the few extravagances we are springing for is a solid white oak paneled front door(see link). The house is located in Iowa and the outside of the door will face northwest. The stoop is fairly sheltered by a 4' overhang.
My builder who is a carpenter/finish carpenter and I will be finishing the door. We have all of the finish equipment available to us, so spraying or HVLP, or hand brushing are all options. I prefer the look of penetrating oil finishes over film finishes, but am willing to go with a film finish if need be for durability.
The question is what finish and process to use? I understand that in any case, the door will require regular maintenance/recoating to protect it.
I'd appreciate any input from exterior door finishing experts out there.
Below is a link to the door with the exception that I special ordered it in White Oak...
Thanks in advance,
Grant in Iowa
Grant's new dream door
Re: Wood entry door finish questions *LINK*
Bill White
>Just got through with the same project. Here's what I did:
Zinsser SEAL COAT shellac as a sealer.
Stain.
Glaze (my choice for added accents).
5 coats per side of OLD MASTERS waterborn poly sanding lightly between coats.
0000 steel wool and MINWAX finishing wax (dark).
I investigated the oil polys and to keep from having to renew the finish every 2 +- years, chose the waterborn. It is expensive, but so is your door.
My door is not exposed to harsh afternoon sun so I expect to suffer less bleaching/oxidation.
We'll see.
Bill
Sounds well sheltered...
John in New Mexico
>Which is very good, and IMHO, means it matters less how you do it. Personally, I've been experimenting with Sikkens products, and they are supposed to have a good two part system for exterior trim, with the second coat being the maintenance coat. If you want a penetrating finish instead of a film, their Cetol SRD seems to work well (and we get A LOT of UV here!). Penofin is a similar product to Cetol SRD, both are available here in custom paint stores. Given how little exposure you have though, you might be ok with just stain (or not, your preference) and a high quality spar varnish.
John
Al Stokka - Cambridge, Iowa
>Grant,
Nice looking door!
I assume you've read Simpson's recommendations for finishing. If not...
Simpson Care & Finishing
Al
