OT Silverado Brakes
Tom Norton
>My 2002 1/2 ton is pulsing when I stop. So I checked the front brakes the other days and replaced the rotors and pads. Still pulsing. Could it be the rear rotors? Or....?
Need some advice.
OT Silverado Brakes
Tom Norton
Need some advice.
Re: OT Silverado Brakes
Chuck W
>Do you have ABS on the truck? It could be worn tie rod ends that shimmy during braking giving the impression of pulsating brakes?
M. McNamee
>Tom, does this occur when the truck is almost stopped? And on dry pavement too? GM has a recall on the front antilock sensors. The front sensors are failing due to corrosion and are giving the antilock 'brain' bad data. BTW this can be really dangerous, although it occurs below 5 MPH the vehicle will take much longer to stop. I almost took out an outdoor ice cooler. I pulled the antilock fuse on both vehicles until it was fixed.
