REAL MILK PAINT
OT - How much UV is blocked by window glass?
Hoa Dinh
>I have an old SLR camera lens. The glass has some sort of rare earth element and over time, turns the lens yellow and every photo it takes has an ugly yellow cast.
A way to bleach the yellow cast is to expose the lens to UV light.
I plan to leave the lens on a window sill (for weeks I think). But if the glass in the window blocks most of the UV in the sun light, I need plan B.
So how much UV is block by the windown glass? My house has double-pane windows, if that matters.
No, I don't have any friend who owns a tanning salon ;-) .
Thanks,
-- Hoa
Re: OT - How much UV is blocked by window glass?
Steve Schoene
>Plain, ordinary double hungs will block about 1/3 of UV, but if you have a low-e coating the UV blockage jumps to 84%. (If you have laminated safety glass (as in Hurricane areas) over 99% would be blocked). These data are from Marvin, assume other windows will be similar.
>As a photographer and a collector of old cameras I don't think that will work. I've seen a lot of lenses with a yellow cast and I believe it's because one of two things. The glue holding the glass elements together is one of the things that turns yellow. The coating on the front of the lens is the color it is because of the thickness of the coating. The color can change by either adding thickness such as oils and grime or by removing the coating by abrasion. I don't believe exposure to UV light would change this but I'm not a scientist and my IQ scores will probably bear me out on this.
I don't think glass filters very much UV unless it's coated or has a gass or plastic inbetween the layers. If it did filter a lot of UV my carpet and photographs wouldn't be fading where the light hits.
DanB
>Hoa,
My bet is that you are out of luck if your windows are close to new. As I recall, you are on the west coast- the part without a cold winter. If that is the case then your windows likily block both the long and short wavelenghs to minimize your cooling load. If you have cold winters you might have windows that pass UV and block the longer wavelenghs to lessen your heating load. If fabrics fade from the sun through the windows give it a try.
Older, regular window glass will pass almost all the UV.
Larry Clinton At Frankfort (Central)., Indiana
>If you have the newer windows, most have been treated with a transparent metallic layer to inhibit the transfer of UV. A quick way to expose the lens to a large dose of UV is to take it to a printing shop with a "Plate burner". These are designed to emit a very high dose of "UV" radiation. I would expect a 5 min. exposure would equal several weeks of exposure in a window. The "plate burner" UV "cures" the material on printing plates so it is not soluble. The areas covered by an opaque negative are not cured therefore can be dissolved, leaving depressions for the ink in the offset printing process. I purchased and used one for a few years. I was an Engineer in my past life (pre retirement) and used it for making metal plates for a "pad printing" process.
I found it! *LINK*
Hoa Dinh
>Thanks for Larry's mentioning of the "plate burner," I was reminded of the EEPROM-erasing UV lamp I used in college. I called around and may be able to get a hold of one tomorrow (the guy has to search in his garage). That will work great for my purpose.
For John and non-believers of this "rare-earth" problem: the symptom and the cause of this problem are pretty well-known, at least among Pentax users. It is most common in Pentax's 50mm f1.4 lens with M42-mount (vintage 1960s) and some old 6X7 lenses. Do a search on "Pentax lens yellow" and you'll find plenty. Below is one of the articles.
-- Hoa
Super-Takumar 1:1.4/50
Re: I found it! *LINK*
JKJ in East TN
>That link didn't work for me, but I found he one below. Maybe the guy can fix my old Sieko watch as well.
However, another guy discussed the gentler window sill method: "Yes, I too have an old 6X7 standard lens 105mm f2.4 that had gone yellow. A month on the window sill (we didn't get much sun in the UK this Summer) and it was clear."
extreme lens repair
