kiln dried wood
kiln dried wood
kiln dried wood
susan
>Gentlemen,
I live in Boston but grew up in Nashville Tn. My family is originallyfrom
Columbia Tennessee.
I purchased a kiln dried fence from a very large fence company
Since the fence was installed in November.. the wood seems to be
peeling (not the paint). The fence company wants to sand down the
grain that is peeling and re-stain.. on site. What should I do?
The warranty is for a year so next year, they may not come out.
thanks for your help.
susan
Re: kiln dried wood
Dale Lenz
Re: kiln dried wood
Dale Lenz
>Hi Susan,
Sounds like you are having growth ring seperation in the lumber, not sure. A pic, close shot, of your fence problem would do wonders.
Re: kiln dried wood
Read the fine print
>From your description of the situation, I'd say you may be stuck with whatever remedy they are suggesting. If the growth rings are separating, which is common in flatsawn cypress, white cedar and other softwoods used for fencing, there's really nothing else to do besides sand and refinish, UNLESS you can get the company to replace all the boards that are flatsawn. The grain separation (due to moisture making its way through the paint or stain) is less noticeable on quartersawn or rift-sawn pieces. Read the fine print of your warranty and see if replacement is an option. Frankly, I can't imagine they will offer to select a particular kind of lumber to replace the offending pieces.
Hope this helps.
Ellis Walentine, Host
