OT - car computer code reader *LINK*
Carol - Strawberry, AZ
>Anyone get one of these things? Amazon has a slew of them. There is no Honda dealer within 150 miles of me. The 'maintenance required' light is flashing and I can't extinguish it.
The local car repair guy may be good but I think I need to be my own second opinion, if you get my drift.
Any experience or recommendations here are appreciated. I have a 2004 Honda Odyssey. If I have to take it to the dealer, I'd like to know I am not doing any further harm driving it 150+ miles to get it there.
Code readers
Re: OT - car computer code reader *LINK*
Tony - Memphis
>I have the small Actron. It has saved me several trips to the dealer. It has worked fine in my 2001 S10. I have loaned it out to others and never had any problems with it. Very simple to use. The Amazon prices are much better than what I paid - around $80 several years ago.
Tony
Thomas S Stockton
>Carol
On some cars that light comes on at certain intervals to let you know it is time for service as opposed to the check engine light which lets you know something isn't right. check the manual to see what it says. Might not need the reader at all, just some electrical tape to cover it until someone can turn it off.
Tom
Even less expensive method
>Electrical tape is expensive. It would cost about $0.005 using that method ;) There is an even cheaper method:
With the Honda Odyssey, you press the trip meter button while the engine is off, start it up and keep holding the button in for 10 seconds (IIRC). And that will cause the light to go off. That's done after oil changes, etc. I believe if that doesn't turn off the light, then it means there the engine wants something more than regular maintenance. But I guess electrical tape will work just as well.
If the light won't go out after performing this trick, as I suspect is the case with Carol, then that might indicate that there is someting other than maintenance that is required.
Happy Woodworking!
A.J. Hamler
Thoughts on the light
A.J. Hamler
>First, go to any major chain auto parts store -- Advance Auto, Pep Boys, etc. They'll read the code for you for free. If they read the code and tell you there's nothing wrong, then it's probably your gas cap.
Remove the gas cap and put it back on, making sure it's on properly. If that was the problem, the car's computer will continue to monitor the gas cap. After a set number of cycles -- varies with the make/model of car -- the computer decides that all is well and turns the light off.
A.J.
Jason Roehl in Lafayette, IN
I hope you have your owner's manual.
>You need to read through it ASAP if you do. On many vehicles, and I don't know if the Honda Odyssey falls in this category, the vehicle needs some sort of minor service if the "Check Engine" or "Service Engine Soon" or "Malfunction Indicator" lights come on and stay on.
If the light is FLASHING, it is possibly indicating a SERIOUS engine issue or a POTENTIALLY SERIOUS problem, meaning if something is not done very soon, major engine damage will result. We're talking something like low/no oil or coolant, things of that nature. I would strongly suggest finding out what the code(s) is(are) before you drive it any farther.
Jason (turned a lot of my own wrenches over the years...)
Don't think you need a code reader
Hoa Dinh in Alameda
>Hi Carol,
I apologize in advance for my questions below. I don't know how familiar you are with cars.
Also, I'm writing this based on my (not so good) memory and will need to check the service manual when I get home tonight.
From what I understand, the 'maintenance required' light flashes when the car approaches the maint. service time, and lights steadily when the car passes the maint. service time if it is not reset.
I don't think the 'maintenance required' light has anything to do with the engine malfunction code. It is the job of the 'check engine' light.
The maint. service time is not very smart. It is based solely on the number of miles from the last time it was reset.
To reset the light, with the ignition off, depress the trip odometer reset button and keep it depressed while starting the engine. Did you try that?
If you need a code reader, try a local auto part store. AutoZone, for example, will read the code for you at no charge.
Please post back with details/new findings.
-- Hoa
Re: I hope you have your owner's manual. *LINK*
sreeb
>If this is the equivalent of the "check engine" light on my cars then "on" means an emissions problem and "flashing on" means you have a serious problem. If this is a separate light then it probably means you are due for some scheduled maintenance.
I have a code reader cable and software from www.obd-2.com. This requires a windows computer to run it. I use an old 266 MHz PII laptop but anything would do. It gives more information than the code reader dongles I have seen and has paid for itself many times over.
Code reader PC cable
Re: OT - car computer code reader UPDATE
>Problem solved.
Loose gas cap, or I should say, not three clicks tight, which is what the book called for.
Whodda thunk?
Thanks for all your suggestions. I never would have found it on my own and no telling what some auto shop would have charged for that fix or the colorful story they would have told me as to what was wrong. I can only imagine.
Thanks. You probably saved me a bundle.
Howard Norman-Prescott, AZ
>Carol, I had the same problem last summer with my 05 Accord. I took it to Prescott Honda and the service writer was honest and tightened the gas cap and told me to drive it for a few miles to see what happened. That took care of the problem.
Howard
>I would have taken it to the dealer, but the nearest Honda dealer is 150 miles away. If the problem had been serious, I don't know that driving it that far would have made things worse. I am just relieved it was something simple.
Carol, who is squeezing tennis balls to get in shape for tightening my gas cap! :)
Technology - how effective is it?
>Technology...... Ha.....
A car is smart enough to tell us (or try to tell us) that the gas cap is loose, but...... won't tell us that we're driving with the gas flap open and looking like an idiot!
Not that I've ever done that, mind you.... but now just you WATCH, I'll drive with my gas flap open today just 'cause I said that.
Happy Woodworking!
Okay - I'll admit it
>Although I've never driven with the gas flap open, I must admit to a perhaps even stupider story. Something that another Honda Odyssey owner can understand.
After owning my Odyssey for 4 years (key point was the warranty expired) I was sitting in a parking lot on one of our long drives with the family somewhere.
My wife was taking the kids to the restroom and needed something in the back trunk which was locked, and yelled to me to unlock it. Well, thinking I was in the car intead of the van, I reached under the seat to pull the trunk opened lever to open the trunk. Of course it didn't unlock the back, so I quickly used the unlock button on the door to unlock the trunk for her.
Then I waited for them.
While I was waiting, I needed to open the back doors for some reason, so I hit the door open buttons on the dashboard to open those automatic back sliding doors.
The passenger side opened, but the driver side didn't.
Hmmm..... that's odd. I wonder why?
I tried again. Nothing.
I tried several times and the driver side rear door just wouldn't open. I thought perhaps there was something wrogn with the switch, so I tried in vain to pull out the switch from the dashboard to see what was wrong. Nothing.
I started to panic a little. Of course, the van was out of warranty, and I've heard that these automatic sliding rear doors are VERY expensive to fix.
Okay, so the button is broken. I'll try the keyfob button. Same thing. The passenger side opened and closed automatically, but the driver side wouldn't.
Dang! Okay, so for now on we'll just have to open that door manually.
So I got out of my seat and walked to the back of the van (note: I didn't get out of the van) and tried to open the driver side back door with the lever. Nothing.
Dang! Dang! It won't open.
This is really bad, I thought. Not only won't it open automatically, it won't open PERIOD. I figured there was no way I was going to get out of a huge repair bill for this.
Dang technology!
So I walked back to the front seat and sat there really depressed about it.
I can't tell you how long I sat there. It was a long time.
Then I got an idea and looked in the side rear view mirror. What did I see?
You guessed it. The gas tank flap door was open. In my haste to unlock the back/trunk door, I pulled the gas tank opener lever under the seat.
So I got OUT of the van, walked to the back, closed the gas tank flap door, got back into the van and..........
VOILA both automatic rear sliding doors worked.
I had completely forgotten that the driver side rear door won't slide open if it senses the gas tank flap door is open. Obviously because the door would break off the gas flap off if it slid back while it was open.
Ha!
I wasted 10 minutes of my life worrying for nothing.
Dang technology!
Happy Woodworking!
Re: Okay - I'll admit it
>LOL
Been there, done that!
But I was outside of the car, filling the gas tank and wanted something from the back seat.
It took about a half of a minute before it sunk it. But I still felt stupid. Dang, you pay all that money for a car and then the darn thing turns out to be smarter or sneakier than you. Sigh....
>The Check Engine light came on in my CRV and I looked it up in the manual. It said to try tightening the gas cap. (What's wrong with this picture. A man who actually read the instructions?) So I screwed the cap on and waited. It said it might take three days. Nope. It seemed to be running fine, so I just kept driving ti. About a week later the SRS (Supplementary Restraint System) light came on. The book said that disabled the air bag. The next morning I am struggle to reorganize my day and get to the dealer and the O2 sensor went out along with something else (ELD Sensor). $650 later, I am back on the road. That little bit of electrical tape is looking cheap. I have had a bunch of Hondas and I love them, but this one is getting the jaundiced eye from me now. It was built in England. Needed a new seat belt. Came from Romania. I did not know they made anything in Romania.
Regular Maintence
Jeffrey D. Rose
>That light will turn come on for about 10 seconds after you start the honda after about 3,000 miles and will stay on after about 6,000 miles. It is to tell you to get the oil changed and air filter and all that stuff. Push in and hold the odometer reset button and turn the key to on. Hold for about 10 seconds and it will go out. I have two hondas and my mom has a couple they all do it. Scared me the first time it went on. Last year I bought a used 1998 accord with 30,000 miles, and after about 1,000 miles the light went on. Did some checking and it was just telling me to change oil and do that stuff. Funny thing is, my wife doesn't know what it is for and I will get in the car and it will be on, but she won't relize it. Hate for the real check engine light to come on.
Jeff in Iowa.
