stupid move - can it be fixed?
Steve Silca
>I am repainting my garage and wanted to caulk som of the gapd that have opened up in the horizontal siding. I accidentally grabbed 100% silicone caulk (the stuff for bathrooms) and began caulking. I quickly realized that I was using the wrong stuff, and switched to normal caulk. I painted the garage with latex exterioir paint and everything looked fine. Then, when it rained, the paint washed right off the 100% silicone caulk. I now have a white stripe in my garage.
Is there any primer or some other process I can follow to get this caulk to take paint?
Re: stupid move - can it be fixed?
wilbur
>It shouldn't be too hard to just dig the caulk out of the joint once it has set for a little while, and recaulk the joint with the right caulk, and then repaint.
Agree
Nat Robison
>I (not a caulk expert) don't know of anything that will make silicone caulk take paint but it will take you just as much time as it will to remove it and re-caulk with latex.
Philip Duffy
>Check at the paint store for a primer that sticks to everything and see if that will fix the problem! I would tell you what brand to buy but my can is empty. Good luck! Phil
Kevin Rabenaldt
>On a church project, some used the non-paintable chalk by GE. I called GE''s hotline and posed the same question. Their response is that there is not anything you can do about it, no paint will stick to it.
Good luck,
Kevin
