I have built a few flag cases in the last several years, if I can help, I'll try. For starters see an early Shot Shot in the link below.
From my FAQ file is the dimensions of the flag cases I build.
Flag Case Dimensions are giving by width x height (bottom to top, not side measurements as many flag case business give) x depth.
The inside dimensions are the following: 21.5� x 11� x 3.25�
The outside dimensions are the following: 23.75� x 12.5� x 3.5�
I�ve been building flag cases since 1993 and have noticed a few things about the Veteran�s Memorial American flag due to customers coming to my home and asking me to put their Veteran�s flag in their flag case. As we all know the Veteran�s memorial flag is the same size, approximately 5�x9�, but the folded flag can be slightly different in size due to two of the following reasons:
� The weight of the material used in making the flag
� How the flag was folded, tight, lose or somewhere in between.
I have built 400+ flag cases over the years and have �tweaked� the flag case size to where all Veteran�s memorial flags have fit to this date. The flag may need to be refolded, but they all have fit, generally with out refolding. My flag case�s dimensions maybe slightly smaller then the measurement of your folded flag but once again I have learned that the flag displays much sharper in slightly tight quarters.
