...but the world may come to an end
Rick Christopherson
>When I first read this question earlier tonight I didn�t respond because the answers were coming in with a balance of information. Now it seems that most answers are nea saying and a touch of fear mongering to boot.
As was said in the first couple of postings, if the dryer outlet does not have a 4-wire connection, then you cannot use it for anything besides a 240 volt load. If both the neutral and ground are present, then you can use this with a portable power distribution junction box for 120 volt loads. Because this is temporary power distribution you do have some options.
First and foremost, because your dryer outlet is likely a 30 amp circuit, then you must use #10 wire for your power cord. Without this, any overloading in your downstream circuits could cause an overheating in the cord. I am sure there are exceptions to this that permit smaller cord, and I�ve probably cited them in the past, but tonight I am not going to go digging through the NEC for references, so I am taking the conservative route.
Technically, you cannot put a 15 or 20 amp outlet onto a 30 amp circuit, so you would need to have some means of over-current protection at the junction box. In reality, I can tell you as known fact that most portable power distribution systems across the country have 15 and 20 amp outlets on 30 amp circuits. (Don�t misread this and assume this applies to permanent house wiring! I am speaking strictly of portable drop boxes.)
The only variation from NEC is putting a 15 or 20 amp outlet on a 30 amp circuit, and even this I cannot confirm as being in contravention in temporary wiring without doing some digging. The reason why I know that this is done across the country is because I build the test equipment that tests the portable distribution systems, and most of them are 30 amps.
To be completely within NEC guidelines, than all you would need to do is install 20-amp GFCI outlets in the drop box that have built-in 20-amp overcurrent protection (most do). So contrary to some of the postings, the world will not come to an end if you do this, and it can be done within the guidelines of the NEC.
Please note that if you were talking about a permanent installation, then my answer would be different, and I would not downplay putting outlets on 30 amp circuits...but that would be the only thing I would alter.
