ADVERTISE HERE - FREE TRIAL
So, I got tired of doing ductwork...
>maybe it was all the trips up and down the ladder.
Re: So, I got tired of doing ductwork...
Re: and decided to finally install...
>the track lighting.
calvin in Irmo, SC
>JL,
Good deal. How about a picture of your under lathe cabinet for those of us thinking about something similar. Thanks.
Re: Here it is... *LINK*
>I took Dominic's idea for a ballast box and lowered it. I then mounted a drawer unit on top of the ballast box. I've got a couple hundred lbs of sand and gravel in bags in the ballast portion.
Dominic's Ballast box article
Hey JL,.
>Good Afternoon JL,
I've toyed with that idea every time I vacuum the lathe room. The dust port looks like it may be a little small for the amount of dust and chips which will stream off your lathe while in use. Any problems with its size? I was thinnking of installing a larger hood.
George
Re: Hey Colonel...
>That all depends what you are turning. They do make larger hoods.
The main reason I have this particular hood is sanding dust from spindles (it will work for bowls also), not chips. I don't breathe chips. I don't mind sweeping chips. Dust gets everywhere.
Also, it will work quite nicely at the end of my workbench. I can disconnect it from the duct by the lathe and move it over to the bench. The narrow opening gives a nice flow across the workbench surface.
