If is possible to screw up, I can figure out how!
arw01
>Using some extra 13.5x13.5 chunks of 1/2 cherry ply to make some scrap wood holding boxes to hold on the walls.
There will be 5 pieces to each, so I dry fit it, figure out I need to cut 1/2 off the back so it's flush with the sides. Well, then I figure out I have to take another 1/2 off to make it sit on a side and then not stick out PAST the other side.
That goes ok, so I glue the back and two sides together and leave it for the night.
Well, this morning I go out to glue the other two sides on, and one side is sticking out back my other side, hmmm.. Seems I glued the back as a side and a side as a back!
Few whacks with a chisel cuts the veneer layer lose, and then I can rip it off.
It's "fixed" now, but I sure expected to stop making such mistakes!
Alan
