OT: thinset not sticking
Pat Evans
>I just installed 1/2" Hardiboard fastened with ringshank nails per the manufacturer's recommendation as underlayment for a sheet vinyl floor. All nails were carefully set no more than 1/16" below the surface, again per the mfgr's recommendation. I used Henry 547 patch on the nails and joints. However, during a light sanding to remove ridges, the patch came out of almost every nail hole. The floor was carefully vacuumed twice before applying the patch. Any suggestions on how to remedy this would be greatly appreciated. I'm up against a Wednesday deadline to get this bathroom finished.
Re: OT: thinset not sticking
Gary Evans Tallassee, TN
>Hi Pat,
How about using the household version of Bondo? I don't know about the cost for your installation, but you can't beat the cure time and the stick-to-itiveness. I would think you could finish it with a putty knife so that you wouldn't see it under vinyl. I know it will stick well to hardboard, as that's how I sealed the vertical seams in my shower.
Good luck,
Gary
Make that Hardiboard instead of hardboard.
