Well, it works
>I have that a couple of that model, as well as about a dozen others.
This one does work, and it was the least expensive, but it's also the cheapest (built) of all I have. Just flimsy feeling.
I keep several in the car with me. I keep them in soft foam padded lunch boxes for extra protection. This one, because it's all inexpensive plastic, really get's looking raggedly in a hurry. Even in it's case. My aluminum cased ones don't suffer the same cosmetic problems. I prefer the aluminum ones. I feel that the metal dissapates the heat better, and that the plastic tends to insulate it inside more. But I have no scientific proof of that.
If you leave it at home, then your biggest concern is the heat. But none of mine have fans, and they all are fine. IF you travel then the prtection of the drive is important. ALumin cased ones are usually better, but not always so. How the drive is suspending inside has alot to do with it. A metal case case transfer all the shock to the drive if it's not suspended inside well.
That's one good thing with this cheap CompUSA one. Because it's all plastic, and the plastic is realtivey soft, the case breaks before the drive is damaged. So like a car with crush/crumble zones, this case protects the drive inside. At least the first few falls.
I haev about a dozen cases plus another dozen or so of external drives. This one from CompUSA is a good price and has had a lot of use and hasn't failed so it's been good, but it's not my favorite.
Then again it's half the price of the other's I like.
Happy Woodworking!
