>I just set up a Rikon 10-325 bandsaw. The final step is to bolt it to the floor. I'd rather have it on a mobile base. Anybody had any success with this?
Also what is a good source of blades? I was hoping to use the Lee Valley blades but they don't make them in 111" as required in my saw.
>Mobile bases are very commonly used on bandsaws, Lee. I can't recommend any brand in particular, but I'm sure some of our visitors will tell you about their experiences.
Regarding blades, many suppliers will make blades to order, in whatever length you need. You might want to see what Woodcraft sells, since they carry that line of bandsaws. Other brands that have been recommended here frequently are Lenox, Suffolk Machinery and Highland Hardware. Google them for contact information.
>Lee - I have that saw and use a ShopFox heavy duty base. Blades are readily available (Woodcraft does carry the Timber Wolf line) and I've had really good results with blades from Iturra Design. No web site though so you have to call.
>cut to order. I ordered it through their website rather than through Woodcraft. I have been pleased with it, although I had trouble getting it to track at first. I think that was because of grime on the tires of my bandsaw and not the blade's problem. You may want to check on the width of the kerf though, my blade cuts a lot wider kerf than I expected.
>Thanks to you all for the advice. I put the Timberwolf blades on my short list and called the folks at Iturra for a catalog. For what it's worth, I mentioned the Woodcentral message board as the source of the tip to get their name.
