Kitchen Light
Kitchen Light
Kitchen Light
Bill Tindall, E.TN
>A while ago I asked about bending thin strips and WC came through with useful help once again. The strips were for 3 kitchen lights like in the PIC. These lights go between cabinet sections over the windows. They are attached to the ceiling.
These lights were surprisingly hard to make. It took some thinking to figure out how to hold them together, but it all turned out well. They are walnut with shellac finish.
Re: Kitchen Light
Re: Kitchen Light
Paul Leuba
>Very nice work, Bill! Please advise us how you attached the curved pieces to the frame.
Paul in Hunt Valley
Re: Kitchen Light
Re: Kitchen Light
Jay in Tx
>Bill,
First off, excellence execution of this project. I'm sure this accents your home very well.
Now, what made it so difficult? Was it attaching the curved sections to the frame? Do the end pieces also contain plastic (opaque) sections to provide more area for the light to shine through? Did you put in some method for easy access to change bulbs, and how did you do it?
Although I don't plan to steal the idea (which is totally worth stealing BTW) the project is neato and well worth knowing how it was done.
Warmest Regards,
~Jay (take out the periods in my name to respond with private correspondense)
Re: Kitchen Light
VERY clever ! And good look'n too !
SteveM
Re: Kitchen Light
construction details
Bill Tindall, E.TN
>I should have known that I could not get away with the sparse details I initially provided.
First I cut out the walnut quarter circles (the ends). A rabbit was cut for 2� on the wall side of these ends and a �� x 2� x 25� piece of plywood fastened into this rabbit to establish the length of the light. This flimsy piece mostly holds it all together. Another rabbit was cut � x � into the inside edge curved edge of the ends. Next, with considerable aggravation a thin strip of walnut was glued onto the curved edge. This arrangement made a frail �dado� for the diffuser to slip in. (Slip implies it went in vastly easier than was the fact.)
Next the front molding piece, with a dado to accommodate the diffuser, was nailed onto the ends (it is the front piece against the ceiling). Then the side molding pieces were nailed on with a miter joint at the front edge. These side pieces have countersunk holes to accommodate trim head screws that fasten the light to the ceiling. They can just be seen in the PIC. The head of the trim head screw was reduced in diameter by � with a grinder.
Then the fun began. The diffuser with it sharp edges was wrestled into the end dadoes without breaking the 1/16� walnut strips. While holding everything in place the final molding piece (the one on the bottom back) was screwed into place and that held the diffuser in place. Finally the two interior thin strips were wedged into the same dadoes where the diffuser went. An enlargement of this dado was made for them where they slip in. The whole thing weighs almost nothing which is good for a light.
Obviously everything had to be prefinished before assembly which further complicated the assembly.
The light is mounted about 2� from the wall so that light flows down the wall as well as out the diffuser.
