OT Corn Heat?
Tom Norton
>Any of you using crn for a heating fuel in either a boiler or furnace?
OT Corn Heat?
Tom Norton
Re: OT Corn Heat?
DB
>Sounds too corny for me.
If you can get the corncobs cheap enough then it should work out very good. My grandmother used to pick up bison patties to use for heating and cooking.
Re: OT Corn Heat?
Ernie Miller
>I used to have a neighbor that used it to heat a kiln for potery not real practicel unless you live on a dairy farm or have a stock yard
Re: OT Corn Heat?
Stuart Johnson
>You might want to do a search on the archives. There was a long discussion on this probably a year ago. My concern would be the cost of corn now with ethanohl (I give up on the spelling)driving up the price.
Re: OT Corn Heat?
Pete in Holland, MI
>Corn does burn well and work well for a heat source. Check with some local distributors on more info. Costs of the stoves are high, but depending on what fuel source your are currently using, it might work out to be a better heat alternative for you.
Research! Research! Research!
