Pattern Question
Pattern Question
Pattern Question
Ron Hildreth, Alta, Iowa
>It's not often that I ever use a pattern to cut a piece for a project, but today I was doing just that, and decided to see what preferences you guys have when it comes to using a pattern. Do you;
1) Use a spray adhesive to mount the pattern to the workpiece?
2) Use heat to transfer the ink lines onto the workpiece?
3) Use carbon paper to trace the pattern onto the workpiece?
4) Other (explain)?
Just curious about this.
Ron in Iowa
Re: Pattern Question
Connect the Dots ! . . .
SteveM
>I do fairly small stuff ( no big funiture and such ) and I've found I don't like cleaning the glue off the work peice if I glued the pattern down. With carbon paper or even pencil my marks seemed to disapear or smudge at WAY the wrong time. Now, at the suggestion of the gurus here, I push-pin the pattern to the work piece then transfer by useing another push pin into the blank. Don't go deeper than a marking gauge scribe would go. Just a prick really. After that you can " connect the dots " with pencil and check your work. Just copy your pattern three of four times first. The one you use is is pretty much shot after all that punching.
>Depends on the pattern.
For the big patterns (I usually use poster board or thick plastic sheets), I use tacks to put the pattern on the seat blanks and then draw out the seat blanks. The tacks or small nails go where I have depth holes, spindle holes, leg holes or arm post holes. The location of the holes is usually critical as I'll be drilling there.
For small patterns, I usually use push pens or a sharp stylus to do the marking and then either play connect the dots or darken the stylus groove. I tried carbon paper, but I gave up because of the smudges and the lines blurring.
Spray photo mount
Ray Thompson - Middletown,IN
>holds nicely and lets you peal off the residue easily.
Ray
Doug Reynolds in Seattle
>Put blue painters' tape on the wood. Use 3M brand 77 spray adhesive or your choice on the pattern, then, stick it to the blue painters' tape. When done cutting out the pattern on the wood, you can remove the pattern and the blue painters' tape all together with no sticky residue.
Robin Corell in Atascadero, CA
>I use several methods depending on the project. for dark wood like walnut I often cut my paper pattern and use a red crayon on edge marking only perpendiculat to the edge of the paper so I dont crinkle the paper.
another option for light or dark wood is to use a sewing pattern transfer wheel or a leather stitch marking wheel to make a series of dots. then to make the dots show up I rub white chalk for dark wood or blue chalk for light woods over the dots and whipe off the excess which will leave a white or blue dotted line. The problem with this method is that it can nearly destroy the paper or at least make it so it tears along the dotted lines. another dificulty with this method is most sewing pattern transfer wheels have excess play as do most of the lower quallity leather stich marking wheels. This makes it hard to track a precise line. A hammer tap can tighten them up a bit or you can track down a high quality one such as a Vergez Blanchard which will run about $60-$120 depending on the model.
Another option is to use graphite paper rather than carbon paper which will leave a mark like a pencil and less prone to smudging. I know graphite paper is available from Dick Blick but it should also be available at other craft supply stores. Another advantage of graphite paper is that the marks can be erased.
Robin Corell
Pouncing
Andrew F in Australia
>While I use carbon paper, this is also where pouncing is used.
Use a dressmaker's star wheel to prick the drawing along the drawing lines, and a bag full of carbon powder to transfer the marks through the pin pricks onto the board underneath.
This is how marquetry was traditionally done, and the origin of the term: "to pounce around."
Cheers,
Andrew
Don Pierson
>I wrote software that prints out patterns for various type of joints and I use "washable glue sticks". I find them in the school supplies for kids.
Thomas S Stockton
>Most the patterns I use are made from 1/4" ply or MDF. I use a couple of different techniques, sometimes I will draw the plans directly onto the ply and then cut it up to make the patterns. most the time I will take a full size drawing and spray adhesive it down to the ply and then cut it out. another glue that works well is called "YES" it's availble at craft stores. their are a few advantages to using 1/4" ply first if I'm going to pattern rout the piece I can use the pattern directly on the jig to get the shape I need, the other advantage is durability a ply wood pattern last a lot longer than a paper one. Also it is real easy to shape thin ply to fine tune the shape you need.
Tom
