"Adjustable" elbow problem for DC ducting
>I'm finally putting up the DC ducting for my shop. Anyway, I ran into a little "snag". The adjustable 6" elbows aren't adjusting. I ordered them a while back and they having been sitting in their box.
I need one of them to make a turn off of a 45 degree "Wye" to make a straight run.
I've given two of them spritzing of WD-40 at the joints. I left them sit overnight. They still aren't budging. The 7" adjustable elbows (which I didn't want "adjusted") rotated fine.
So - how do I go about rotating them? I don't want to pry at the joints too much as this would compromise the suction (though I suppose I could duct tape them). Home Depot does not carry strap wrenches in a large enough size to use on 6" ducting.
Also, does anyone see any problem with using lighter gauge (30 gauge) reducers for a 2 hp cyclone? TIA.
Re: "Adjustable" elbow problem for DC ducting
Brute force
>Assuming someone didn't secretly put Locktite in there or spot weld the joints, I don't know of any way to rotate those adjustable elbows other than more force. Maybe you can get a helper to hold one end while you rotate the other. Or how about making a plywood disk to fit inside one end of the duct. Screw it to a table or bench and then screw the elbow to it. Then try turning the connector.
Regarding the use of light-gauge fittings, it may work fine for small pieces as you suggest, but maybe not. Definitely don't try it on longer runs. We once had a 12" round duct about 15 feet long that was sucked flat by our 5hp blower. I think it was 24 ga pipe. The resistance to deforming is relative to the length and diameter. It doesn't cost you much to try a lighter coupling, and if it doesn't work, get a heavier one. Or forget trying to pinch a penny up front and get the heavier gauge to begin with.
Re: Brute force worked...
>I put a piece of 1 x across the diameter and put some sheet metal screws in either end. Held the 1 x in the vise and was able to rotate it using both hands.
Thanks.
>JL, glad you were able to rotate the fittings. Look at them closely. I am not sure (its been a while) but I think if all the sections to rotate you will find the fitting become sort of "3 dimensional". Lay one on a flat surface. It should have "flat sides". Not sure it matters or at least, not much, but your system might "look" neater if you rotate them correctly. Pick two of the swivels and rotate those two fully.
I doubt if your system will collapse short fittings. The ribs tend to reinforce them as do the joints tot he next pipe or fitting. If you want to you can reinforce them by making mounting brackets that include a snug fitting circle of plywood around the outside. The rings don't allow them to "go oval" which is how a collapse starts.
>It is really a question of "parts" so to speak.
I find that I did not get enough reducing fittings (6 to 4") and I need one more "Wye". I've looked at the "Wyes" at the Home Despot, and I'm thoroughly unimpressed. The reducing fittings are worse in that the crimps are off and they don't appear to be that good. Sigh. I'll put in an order to Oneida Air on Monday.
