OT GMC Truck Air Conditioning Problem
Rob Sandow
>I figure there may be a few people on WC with this problem. My 2001 GMC 2500HD has a problem with the air conditioner. Everything works normally when the truck is first started up. When the truck warms up to operating temperature, the A/C begins to blow warm air, but only if the truck is being operated in city driving conditions. If you take it out on the highway or a country road and run it over 40 MPH or so, the A/C starts working again.
There is some evidence on various internet sources that the problem could be a "low pressure cycling switch", but there are some other possibilities I've come across also. I expect that a dealer or other mechanic will misdiagnose this and decide to replace the compressor or some other high cost operation, when it could possibly be a low cost fix like this switch. I don't really want to go there without knowing what I'm talking about.
So has anyone else had this problem with a GMC? If so, did you find out what the cause was? How much did it cost to fix? Thanks.
Rob
Re: OT GMC Truck Air Conditioning Problem
Chuck W
>Sounds like it may only be low on refrigerant.
Joseph Mulherin
>that is exactly what is wrong with the GMC truck mentioned. Go to the auto supply, buy a recharge kit and a couple cans of #134 refrigerant. connect the hose to the low side of the dryer...probably the blue cap...and turn the can upside down and fill up the system. of course have the truck and a/c running. couple cans will fill it up fine and you will be back in good operation again. use the refrigerant that has the sealer with it. run you a/c during the winter season so that the seals are lubricated and do not let the refrigerant out....do this at least twice a month in the fall, winter, and spring too. Good luck
Jason Roehl in Lafayette, IN
>Don't take it to a dealer if you don't know one you can trust. Ask around and find a reputable place that specializes in non-engine mechanics. I got my A/C fixed at a place that is mostly known for mufflers and suspensions, but are very reputable. If it is low on refrigerant, then you have a leak and it needs to be fixed. Anything less is a band-aid. Getting the kits and cans at the auto store yourself will likely only last a short time and could lead to other parts of the system breaking down. Let the pros with the right tools do it.
Jason
Earl
>Rob I had that exact same problem on a Dakota. I lived with it for awhile then it (engine) started getting hot sitting at stop lights. I washed the radiator (fins) out with a hose also washed the ac thing out to since it was right there. It started running cool again and the air started working much better also. Don't know if that will work for you but it would be cheap to try. luck to you. Earl
Matt Prusik
>Rob:
Before you go spendign nay realmoney, I would make sure the coolant level in the radiator is correct, that the fins on the radiator and AC condenser are free of debris (a hose wash like one of the messages below will fix this) and make sure your serpintine BELT feeding the AC compressor is TIGHT.
I just had a similar problem in my GMC van and it turned out to be a loose belt.
Good luck.
Matt
JD in Memphis
>I too have this problem and it is driving me nuts. I have a 2002 GMC Sierra 2500HD and you discribe the problem exactly. I am going to try the tips mentioned here in assending order of cost and see what happens. Here in Memphis we've had heat indexes over 100 degrees for over a month straight. Would love to get this fixed. Thanks for the advice.
JD in Memphis
Larry Clinton At Frankfort (Central)., Indiana
>All automotive type air conditioner leak to some degree. This is due to the seals on the compressor allowing a small amount to bleed through. Most other units are electric - refrigerators, freezers, dehumidifiers and air conditioners. These are "hermetically sealed" with the motor and compressor sealed (often welded) in a metal container. The belt drive automotive units can't be sealed as the units are belt driven and all rotating seals leak to some degree. Therefore all units will require addition of coolant sooner or later. I am currently driving my 1989 Dodge Van with 115M + miles - air conditioner works well - but I am out of freon 12. I have been adding about a lb of freon every year or two for the last 7 years, used my last can this year. Finding R 12 has been a pain but I have been lucky at Estate auctions. I will have to convert mine to a different coolant - probably next year as I have a few "bubbles" in the sight glass. I'm looking at some of the new universal replacement cooling gas. For those with the R134A in the systems, I would purchase a recharge kit and follow the instructions to refill the system prior to having it serviced. Kits usually run less than $40 at the automotive stores - while the service charges usually start at $100 - and go way up from there. Midas quoted me a minimum of $350 to convert mine - I couldn't get out of there fast enough - though hard to move fast while laughing so hard!
Joseph Mulherin
>You are right, Larry, about the seals leaking. That is why I said to run the compressor a few minutes each month just to keep them oiled up and soft. The oil is in with the refrigerant when they are put together for initial service.
Now, you can purchase a kit to refurbish the R12 systems to start using R134A. The kit contains a couple nipples that go onto the R12 system and make the system ready for the 134A installation hoses to connect to with the 134a fluid. You cannot use 12 anymore....why???... because the R12 was found out that it depletes the ozone and allows the sun to come thru and affect our atmosphere. We need to have the ozone to protect us from the harsh sun rays. So, if you still have the R12 system....change it over to the 134A system....now.
Pete in Holland, MI
>Had a smiliar problem with my 2001 1500. Turned out to be the control mechanism on the heater unit itself. Dealer took care of it.
