OT tire foam?
OT tire foam?
OT tire foam?
Phil Joines
>We have lots of thorny trees and bushes around the place so I'm always fixing flats on the mowers, etc. Is there a foam rubber kind of thing that can be injected into the tires to replace the air? I've seen solid tires but they're pricey and not available in the sizes I need.
Re: OT tire foam?
Go to Gemplers.com
Ray Thompson - Middletown,IN
>They have two different grades of stuff to put in your tires. Its lasts me about 2-3 years before I have to put in more but it does work.
Ray
Re: OT tire foam?
Slime works!
Lee Schierer - McKean, PA
>I don't know if it is still avaialble, but a product called SLime works.
Lee
Re: OT tire foam?
Jim DeLaney, Austintown, Ohio
Re: Slime works!
>Yeah, Slime definitely works! I've got it in every tire around this place - tractor, pressure washer, garden trailer, wheelbarrow, pressure washer, hand truck, plywood handling dolly, roto-tiller, and oh yeah, in two of the tires on my truck. Haven't had a flat in anything since I've been using it.
Harbor Freight has it cheaper than anybody. I recently paid $29.00 for a gallon of the stuff.
Jim D.
Re: OT tire foam?
Yes they do.
Basil
>Sorry but I'm only familiar with using it in heavy equipment tires.
I'd start by calling a large dealer that does heavy equipment tires and asking about foaming your tires. If they don't do smaller tires maybe they can point out someone who does.
On second thought, call a skid steer dealer, someone like Bob Cat, John Deere or a CAT dealer. I know they do skid loader tires.
Re: OT tire foam?
Get it in Lowe's Seasonal Dept.
Craig in SIlverdale
Re: OT tire foam?
Re: OT tire foam?
Robert R Clough - Thorncraft
>Apparently the stuff does does work. I have never used it because, over the years, every garage/tire person I have ever talked to has said not to use it. I gather it really messes up the inside of a tire.
Re: OT tire foam?
Re: OT tire foam?
>I've never tried to clean it out of a tire, but, for whatever it's worth, the label says "Water Cleanup." YMMV...
Jim D.
Re: OT tire foam?
Re: OT tire foam?
Phil Joines
>I can get replacement tires mounted on new wheels cheaper at Tractor Supply than the cost of just the tire anyware else. They just don't hold air very well :>).
Re: OT tire foam?
Further explaination of "foam".
Basil
>I think most people in this thread are refferring to "Fix-A-Flat" or "Slime" in their responses. "Fix-A-Flat" does ruin the wheel if left in the tire for to long of a period of time (Rust). "Slime", or at least the 5 gallon buckets of soapy stuff I think they're referring to, doesn't rust the wheel and only seals slight leaks and bead seating problems on fresh mounted tires. (used to pour 5 gals. in a new pan tire and a month later if you had a flat it would be gone)
"Foam", or at least what I thought you meant from your original posting of ".... Is there a foam rubber kind of thing that can be injected into the tires to replace the air? ..." takes special equipment to inject into the tires. That's why I recommended that you find someone in your area that has had it done to their tires. Most places that rent Skid Steer Loaders have their tires "foam" filled.
I should have explained (unless things have changed) that after you have your tires "Foamed", you should consider the tire and wheel as "one". "One" as in you throw it all away (tire and wheel) when worn out (can be removed but it had better be an expensive wheel that you need to save). Expensive "Foamed" tires on heavy equipment can be recapped (on the wheel) and used again by a 'cold' capping process called "Bandag". But for the sizes I think you're talking about, it's not practical and you probably couldn't find anyone to do it.
Also, "foam" filled tires are not for high speed use which I don't think is a concern in your case anyway.
Re: OT tire foam?
what about inner tubes?
albertabob
>I have some garden tools with inner tubes in the tires?
Will any of this stuff work and how do you put it in if it does?
Bob
Re: OT tire foam?
hmmmmmmm?
Basil
>All I've seen "foam" used in was tubeless heavy equipment, severe service, tires. The "foam" adheres to the tire and whell replacing air as the inflating agent. Picture the tire as being solid with a soft core and a hard outer shell. I don't think filling an innertube with "foam" would work because of slippage and wear between it and the tire and wheel. I know in heavy equipment they don't recommend running a tube (with air) in the pulling tires. The tubes tend to 'creep' and pull the valve stems out of the tube. Trail wheels however just roll and can be run with tubes.
Now for your question: For lawn stuff with a tube I don't think you would want Foam. You could use "Fix-A-Flat" and/or the "Slime" in the tubes probably without having to worry about any damage to the wheels. Getting the "slime" in the tube might be a problem. I've never put it in an innertube. We always poured into the tubeless tires from a 5 gallon bucket during mounting.
I guess you could get one of those devices used to put water in tractor tires to get it in the tube. The device screws onto the valve stem (minus the needle valve/valve core/ inner thingy) and attachs to the garden hose. You could make up a rig with this device to pour some "slime" into the innertube. That would fix minor leaks and problems to extend your re-inflat time periods.
Re: OT tire foam?
I always leave something out.
Basil
>"Fix-A-Flat" is a brand name popular at least around here. It can be found in some form at most any auto store. It's in a can, under pressure, has a short hose and is usually used to inflat flat tires in an emergency. I usually (but not at the moment) keep a can in the trunk for an emergency.
Re: OT tire foam?
Re: I always leave something out.
albertabob
>Thanks Basil.
I will give it a try. Worst that can happen is to have to buy some new wheels and tires.
Bob
Re: OT tire foam?
Re: READ the label!
>Where it tells you to notify a repair shop if you have the tire / wheel worked on. I seem to remember that there's some risk of very bad consequences if they simply try to pop off the tire.
mm
Re: OT tire foam?
Re: READ the label!
albertabob
>Hi Mark:
I was just trying to renew a couple of carts like this that we use around the yard and the tires are always flat.
It's A SUPREME pia and I thought this might be a work around.
Rgds
Bob
Re: OT tire foam?
That's it!
Phil Joines Krum, Tx
>I'll call around to find someone. I think the tires are cheaper than they used to be, just don't hold air very well.
Re: OT tire foam?
Re: That's it!
Dan Donaldson
>I didn't realize that they were bicycle type tires. They make thorn proof tubes and puncture liners for bike tires that might do what you need.
Re: OT tire foam?
Re: That's it!
Dale Stansbery
>And you can get them At WalMart for about $5 per. I put one in a bike this spring and it's held fine.
