Advice needed on floor
Nathan
>Hi all, it's been a long time since I checked in here... of course, I'm doing so now because I need some help.
My wife has finally convinced me that it's time to do the upstairs floors. They will be tongue-and-groove pine boards, a tad over 1" thick (27 mm - I'm in Europe). I've already purchased those so their thickness is fixed.
The substrate is concrete which has been leveled using a special levelling mix so it's more or less dead flat.
I'm currently in the process of preparing the "stickers". These are thin boards that will be anchored to the concrete substrate and sit between it and the tongue-and-groove floorboards. I'm making the stickers from plainsawn 2" thick pine boards, so the dimensions are two-by-something inches. Now, the question is, what should the "something" be.
These pine floors will be in the three bedrooms, each of which opens onto the hallway. The hallway has an existing teak parquet floor (which is dazzling, BTW, but too expensive to have in all the rooms). Now, this existing teak floor in the hallway is 47mm (1.85") above the concrete substrate. Of course, I'd like to get the pine floor as close to level as possible with the teak floor. However, subtracting 1" (the thickness of the pine floorboards) from 1.85" you're left with 0.85" which, methinks, is not enough thickness for the stickers.
So what, in your opinion, is the minimum thickness for the stickers so as to minimize the height difference between the teak and the pine? Of course, I will make thresholds to disguise this difference but we still want to minimize it.
One piece of relevant information here: I decided to use screws instead of nails to attach the floorboards to the stickers. I'm planning to make a jig that will allow me to predrill through the groove into the sticker at a 45-degree angle.
Right now I'm thinking 1" thickness for the stickers, which puts the height difference at 0.15" (about 1/6"). Do you think this will be enough material to hold those floorboards to the stickers?
On a related note. I'm planning to space the stickers about 22" apart. Is this overkill given the floorboards are 1" thick?
Thanks for any and all replies.
Nathan in the Czech Republic
