Have a question? Ask Woody!
Wireless smoke detectors
Lee Schierer - McKean, PA
>I was in one of the local borgs the other day and noticed they had smoke detectors on the end of an aisle. Because LOML was tied up at the returns desk, I read the label and noted that one of the boxes said "Wireless", so I read more. Apparently you can mount several of these in a house and if one goes off, they all do, yet there are no interconnecting wires. The package was sealed up so I couldn't determine how far apart they could be and still communicate with each other. It also wasn't clear how many you could have in a given area. Kidde Wireless System is the name on the box.
I know the question has come up several times from folks wanting to protect remote shops.
Lee
Lee
I know there have been questions earlier about having
Re: Wireless smoke detectors
Gary Ratajczak
>Saw this on their site. I'd also like to hear from someone who has them installed.
HOW THE KIDDE WIRELESS SYSTEM WORKS
Q: What is the furthest distance through which the units can communicate?
A: Every home presents obstacles that can affect the transmission efficiency of a wireless system. However, extensive field-testing has shown that the Kidde Wireless System is very capable of transmitting in all reasonable environments. It is always important to test wireless units after installation to make sure they work properly.
Mike DeHart, South Jersey
>I installed these in my house recently. Three story Victorian with basement, built as a duplex but always single family owned so there are doors between the two sides. It is a large-ish house that is mirrored on each side of the center wall. I put 5 of the detectors in. One each in the two basement stairwells, one each at the top of the two main stairwells, and one in the open attic. I like 'em! Smoke on one side will alert both sides on all levels. If I burn the crap out of something on the stove and it sets off the alarm at the top of the stairs, I don't have to run upstairs and get a ladder to reach that particular alarm. I open the door to the basement and push the silence button on that one, it shuts them all off.
Wireless just isn't....
>I don't care what anyone says. Wireless communications, of any sort, are just not as reliable as wired connections.
Happy Woodworking!
Re: Wireless just isn't....
Howard Norman-Prescott, AZ
>I understand your comment Mark but if you don't have the wiring in for multiple wired smoke detectors it sounds like the wireless ones would be a good choice. Retrofitting the connecting wiring for smoke detectors can be a bear.
Howard
