What is this tool?
Max
>Anyone know?
What is this tool?
Max
>Anyone know?
Re: What is this tool?
Jeffrey D. Rose
>Looks like it is a string winder. You can wind construction string around it and undwind it really easily on the job site.
Just my thought.
Jeff in Iowa.
>I'm pretty sure it's a combination paint scraper and ping-pong paddle. And I defy anyone to challenge me! ;-)
Tom
Ernie Miller
>Play dough mold for Brio train tracks.
Max
>Doesn't look like the Play Doh mold.
Any ideas?
I challenge you
Tom Sontag - St. Louis
>to a ping pong match with paint scrapers!
I had a feeling you'd chime in!
>How about paint scrapers at 10 paces? High noon? I'll be wearing my pearl handled scrapers of course.
Tommy The Kid
A watch band tool.
Max
Re: Piercing instrument.
Al Stokka - Cambridge, Iowa
>The handle (right side) has a threaded adjustment and the needle inside is spring loaded. Works like a pin ball shooter.
The narrow slot on the left is for ears and tongues. The wider slot on the right is for, er, uh, well, other body parts.
Al
Dave in Haverford PA
>Send it to "What is it?" on This Old House!
Bill White
>It is a Crinnix, and works in conjunction with a Frammus allowing folks like me to convert from RAS-only use to joint efficiency on both RAS and TS because with those devices, you can get the table surfaces to within .00000001" coplaner.
WHEWWWW! Now I have a headache.
Bill
Actually
Dan Donaldson
>It is for adjusting the muffler bearings on a Stanley #8.
Marv
>Are you sure it's a tool? Perhaps it's part of something else.
Marv
Actually, it's more commonly used
>Actually, it's more commonly used to adjust the concentric timing vaccum on circuit boards used in micro-crystalized radio bearings whenever lead-acid second chains are problematic.
Happy Woodworking!
Re: Step right up and buy one *LINK*
Dale Lenz
Watch band tool
DB
>Kinda looks like a drill press vice. Could you post a larger picture? What is the size of the object?
Steve Schoene
>As said, a vice or clamp. Perhaps to hold cabinets together during installation?
Any fool can see..
Phileas But it appears Dale nailed it; it's a watch band tool. Phileas
>It's an alarm clock.
