Saw fence flatness...
Mark Harrison - Brisbane, Australia
>I recently bought a Powermatic PM2000 saw and I now finally have the darn thing setup mostly how I like it. The top was way out of alignment with the arbor to start with and I have reset that correctly. I had to buy a Masterplate to get it right but I'm glad I did. There is still a variance if 1/100 of a mm from one end to another but that is probably close enough to blame the dial guage or the plate. I think it got this way because the top wasn't bolted down tight enough to start with.
Now I have another problem, or perhaps a non-problem. I attempted to align the fence and noticed the dial guage dipping and peaking all over the map. I put the straight edge on it and it was immediately obvious why that was. That's because it does peak and dip all over the map and we're not talking little bits all the time either. So I spent the afternoon in the loosening/packing/tightening cycle on the blasted fence. It's still a long way from perfect.
Am I being too obsessive/compulsive here? Is this par for the course for the plastic fence faces? The fence itself is not that flat either but the majority of the problem is the face.
Maybe I should just make a melamine or plastic laminated plywood face. It couldn't be any worse than what I have.
