Another Totally OT, but interesting *LINK*
Dan Donaldson
>At least to me;-)
Warning, high speed connection required
Sulfer Hexafluoride
Dan Donaldson
>At least to me;-)
Sulfer Hexafluoride
Re: Another Totally OT, but interesting
>OK - so if you mix it with the correct proportion of helium, will you sound normal :)?
Among other things, SF6 is used to
Bruce, a MN Galoot
>extingish the arc created when a contact is broken inside high voltage circuit breakers. I'm not sure I'd inhale it like this guy did.
Interesting!
Bruce
JKJ in East TN
>Yikes, anyone who is tempted to inhale some gas with abandon should see the training demonstration of how bacon bursts into flame when touched by a puff of fluorine. It would do the same thing to human flesh.
Also, heavy gasses are a real asphyxiation hazard as they can accumulate in low places. Helium is fun and less of a hazard, but even so people have suffered injury when falling after passing out from oxygen deprivation. I've heard of lung damage from sucking pressurized helium directly from a tank. I use helium around small children but keep the helium tanks locked up.
But demonstrations with gasses can be fun and educational. One of my favorite is to fill balloons with various gasses and let kids like up and have a "contest" to see who can throw them furthest across the room. A balloon filled with freon can be thrown like a ball but one with helium/air mixture might only go a foot or two.
Going around a corner is fun
Charles R. Smith from Victoria
>I used helium-filled balloons to teach my kids a lesson in physics. We had some balloons in the car, and I asked them which way the balloons would lean when we went around a corner quickly. They predicted that they would be forced to the outside of the car due to the centrifugal force. Of course, the balloons moved toward the centre, thanks to the fact that they are lighter than the air which itself was forced to the outside.
Charles (who still likes birthday parties with balloons)
Re: Going around a corner is fun
JKJ in East TN
Me too! I keep two tanks on hand and often make balloons for the kindergarteners as incentive prizes.
BTW, do you know about the liquid plastic you can get to put into rubber helium balloons? I bought a quantity from a party supply store once. Squirt a little into the balloon and squish it around to coat the inside and the helium does not leak out so fast. (The helium atoms are so small they will even leak through glass!) I did a test once with two balloons, one without and one with the plastic. The first one was on the floor after the first night, but the second one stayed up for 10 days!
The stuff is very thick and gooey, so when I get it out for the kids I ask them if they want the balloon with or without Elephant Snot. They always want the snot! :)
That's fascinating -- never heard
Johanna
>of the stuff. What is it used for?
youngstrom
>Actually SF6 is completely inert and is not the same as F2 gas (I used to burn pork chops in F2 as a demo...) There is a real danger however in that there is often a trace amount of SF4 in SF6 which is highly toxic.
It is also used medically
Dan in Northern California
>to treat retinal detachments. It is injected either undiluted into the eye during surgery as a temporary tamponade to keep the retina reattached, in which case it will expand to twice the injected volume. It can also be injected after dilution to 20%, which is the nonexpansile concentration. It eventually reabsorbs into the blood stream after 3-4 weeks and is well tolerated in the small volume used. Some retinal surgeons actually keep a tank of the stuff in their car. I am not sure many of them are aware of all the fun things one can do with it.
Dan
JKJ in East TN
I think most people realize that. The point is if you choose to mess with or actually inhale some gas you darn well had better be 100% certain of the gas and what you are doing!
I have a friend who found two old gas cylinders on his new property left by someone who passed had away. HOPING he had a cylinder of helium, he tried putting some into a balloon. Ack! Fortunately, no harm was done but it could have been a fire or explosion hazard or worse.
