O.T. : TV Plug Wire
Nick Tuzzolino
>Is it illegal or unwise to run a wall hung TV outlet cord inside the wall with the other accessory wires? It will be about a four foot straight run from the back of the TV to the outlet directly below.
O.T. : TV Plug Wire
Nick Tuzzolino
Re: O.T. : TV Plug Wire
Tom MacGregor
>It's not a good idea, and definately against code to run a line voltage (110-120 volts) cord inside a wall unless it's specifically designed for that purpose. Speaker & antenna wires, etc. don't usually carry nearly as much current and are generally less of a hazard. You could get away with a surface mounted plastic "cord management" cover like those used to bundle computer cables, but don't bury lamp or extension cord inside the wall.
JKJ in East TN
>Houses have burned from such wires. One reason is mice chewing; another less likely cause is expansion/contraction from temperature changes slowly causing the insulation to wear through, however 4' probably isn't a long enough run for the latter to be a problem. (I've seen this happen to cable TV runs.)
It should be a fairly quick job to run a new outlet to a location in the wall just behind the TV and should cost less than $10 if you do it yourself.
Dan Donaldson
>Agreed, don't do it. Against code and If something goes wrong and your house burns, you might get a refusal to pay because of it.
Just as an aside, speaker wires are not always ok either. I have a power amp that specifically says that you cannot run the output inside of a wall unless it meets the codes for regular house wiring. (It can deliver over 100 volts at 10 amps, which lights a lightbulb just fine ;-))
Tony - Memphis
>I have some mantel lights hooked up via an extension cord hidden inside the mantel. I don't really see the problem. No different than running it on the outside at least in my case.
Re: O.T. : THANKS!!
Nick Tuzzolino
>It didn't seem right to run it in the wall. Being it is such a short direct run, I'm going to put an outlet behind the TV. Thanks again. Nick
Re: O.T. : THANKS!!
Nick Tuzzolino
