drum sander abrasives questions
Ken Platt (North Granby, CT)
>Folks -
As noted in a thread a little ways down the board, I just purchased a small drum sander, the Jet/performax 10/20, to help me with avoiding planer tearout on figured woods.
So now I need some abrasives, and I had a few questions. First, do folks with these sanders use pre cut, or cut themselves from rolls? The price difference (for me, about $3 vs $5 per wrap)seems a bit much for a small convenience, but I was wondering if I'm missing something?
Second, is it worthwhile to pay extra for the blue zirc rolls vs regular aluminum oxide? I have used blue zirc material for other sanding, and have found that in belts for my disc/belt sander, it really does seem to last much longer. In disks for my ROS, it didn't seem to last any longer before the disk itself got pretty frayed at the edges (of course, that could also mean different quality, I suppose)
Lastly, any tips on particularly good vendors would be appreciated. So far I have checked Klingspor, Industrial Abrasives, Supergrit, and A & H (part of Woodworkers Supply, apparently).
Thanks -
Ken
Re: drum sander abrasives questions
Paul Woolson
>I buy mine in rolls. I use a dual 25" drum sander and go through them pretty often, it gets lots of use.
The purple stuff is good as long as you aren't using resinous woods. If you load it up with pitch, it doesn't matter what kind of paper you have, it's worthless.
Klingspor has been my vendor of choice though I'm sure there are equally good vendors out there. And another tip, don't look at this thing as a finish sander. You'll need to use coarse paper or you'll have all sorts of heat build up problems. I use 60 on one drum and 80 on the second. That works well for me.
>As I mentioned in the other post is I am still using the Performax Jet abrasives. I Checked out their rolls and found that for my 16/32 the precut strips only cost about a dollar more than the rolls. Its worth that to me not to have to cut them myself.
The instructions that came with my machine said if using other than Performax abrasives Use (X) weight polyester backed aluminum oxide, open coat, resin bond.
As far as cleaning the belts goes, I have just had the experience of trying to sand some VERY resinous heart pine. One 44 inch long piece completely gums the belt about half way through. The lead end would be sanded and the trailing end shiny from being polished by the gummed belt. Wood dough on the belt at least a 1/16" thick. I cleaned them by soaking them in a solution of about 50% Simple Green.
Had to run them through the solution twice. Soaked them overnight and scrubbed them with a brass veggie brush. First pass through got most of it and the second got the rest. It was stunning how much gook came off.
Vinegar will help if you get glue on them. Oven cleaner will work on the REALLY nasty ones. My belts cost $7 and even though this cleaning process sounds time consuming its not that bad. They soak for a while and then it takes about ten minutes to scrub them. I have left the belts soaking for a week or more and it did not seem to hurt them.
On less resinous woods the crepe rubber cleaning sticks work well. Then you soak them after a while. Usually one soaking is enough.
