200+ woodworking book reviews
OT-Fire alarm kept going off last night
Mark in B'ham
>I am bleary eyed today. We have fire alarms that are wired into the house current and the upstairs one went off about 1:30 in the morning. Scared number one son (4 years old) so LOML took care of him while I searched the house for smoke. I couldn't find anything. I finally cut the power and disconnected the alarm.
Does anybody know about these things? I think I should replace the alarm, but is there anything I should be doing in addition? Thanks for your help.
Re: OT-Fire alarm kept going off last night
doug f, san clemente, ca
>Mark - I had the same problem a couple years ago. Fire Department was out twice in one night; they weren't real happy. On close inspection we found teeny little spider webs in the detector. Given that it was five years old, we just replaced it. No problems since.
Good luck.
Doug
Thanks Doug
Mark in B'ham
>We have been having an ant problem in the house (the little ones that form lines around the whole place. I suspect them, but I suspect them for everything that goes wrong. Thanks for the input.
Bill Hammond, Oregon Coast
>Smoke detectors seem to generate just enough heat to make it a nice place for spiders to nest, or perhaps it's just convenient and dark. Vacuum them often to keep them out and at least once a year take them down, open up and clean out. In some places with lots of bugs like basements we would put a small slice of "Shell No Pest Strip" into the detector. Not to be done in living spaces.
Photoelectric detectors are more prone to false alarming with bugs while ionization detectors will respond to some cleaning chemicals and a ripe kitty liter box
If your detectors are wired into a central Fire/Burg alarm system the detectors should be cleaned when your system is serviced each year.
Properly maintained a quality smoke detector should last until it's killed by lightning or otherwise damaged.
I will add that if you have never vacuumed your detectors, the first time you do so may make it go into alarm.
hth
Bill
Wow, I never knew...
Mark in B'ham
>I thought that since the detectors were hard wired, I didn't need to do anything. So, I think I will just change my daylight savings time ritual to a vacuuming job. I'm still going to replace the ones I have now, though, just to be sure.
Thanks
Re: Wow, I never knew...
Glenn Madsen near San Francisco
>We had a 'beeping' alarm the other day. I didn't know if it was a battery thing, or if it was sensing the grass fire in the parkland a couple miles from here. Changed the batteries, and the fire team got the fire out, and the evening breezes came up, and all it pretty good now.
In my part of the world, fire is one of the things we are really concerned with. The world dries out pretty good from June 1 through November, and it's fire season. There are 5 or 6 detectors in our 1700 sq ft house...
New detectors every 5 or 6 years is just money spent well.
Bob Persing
>Just a FYI-
Check the box or the smoke detector itself. Many, if not most, of the ionization type smoke detectors sold for home use have a finite lifetime and will need to be replaced to maintain adequate protection.
Carbon Monoxide detectors also have a finite life, shorter than that of the ionization type smoke detectors, and need to be replaced periodically.
BobP
loft guy
>Hi,
You might want to consider replacing the hard wired smoke detectors with models that also have a battery backup so they will function in the event of a power failure.
Bob
We are going to mount another with a battery...
Mark in B'ham
>to work in tandem with the hard wired detectors. We got one of those new ones that you can record a message for the children on. I think this is probably a good idea seeing the behavior of our two boys last night. The four year old was just scared and sat in bed hiding from the noise and the almost two year old slept right through it all.
Thanks for all the good info. Y'all are more than just good woodworkers, you're good folk.
Martin from Granbury
>We had spiders in one of ours, but ours also go off when it is time to replace the battery. Of course, that never happens in the daytime, only at 0300.
Smoke alarms need to be replaced
>I believe ?most/many/some? smoke detectors clearly state that they have a limited life and should be replaced every 5 or 10 years, can't remember which. I replace batteries every 6 months and the detectors every 5 years.
Something to do with the radio-isotopes irradium half-life... no just kidding. But there is something about the chemical elements in smoke detectors that require replacement.
Happy Woodworking!
Jason Roehl in Lafayette, IN
The battery companies just want your money!
>If you replace the batteries every 6 months, you are simply wasting money and batteries. In my last house, we didn't change the batteries for years, probably in the 5-6 year neighborhood. On top of that, the smoke alarm was near the kitchen (small house), so it would nuisance trip probably 2-3 times per week. We didn't even have to be burning anything, just turning on the oven would often do it. I believe in "better safe than sorry", but this twice a year business is overkill IMO and IME(xperience).
I think the standard lifespan on a detector is 10 years due to degradation of the minute quantity of americium (235? 233?) inside, and there's probably a bit of "better safe than sorry" involved, too....
Jason
That's what I meant
>I had "CHANGE" on my brain when I wrote that.
I replaced all the smoke detectors when I moved into this house, and then again a couple of years ago. Guess it was 7-8 years between replacements. And you're right, I check the detectors every 6 months, and carry some batteris with me on my rounds in case I need to repalce them, but I don't need to repalce them that often.
"...due to degradation of the minute quantity of americium (235? 233?) inside...."
Ya, that's it... isn't that what I said ??? ;)
The stuff that Marvin here kept on loosing ;)
Happy Woodworking!
Smoke alarms are too sensitive for shops but
Keith Newton
>I know this is not your problem, but if any of you want to protect your shops, and are on burglar alarms, you can get a sensor that will trip if the temperature rises very rapidly by X number of degrees. This solves the problem of false alarms every time you sand a project, or generate a lot of dust sawing.
DB
>If you are sure that the kids were not smoking (most likely not in your case but possible), then the problem could be the build up of dust, someone taking a shower with the door open near the detecter, insects, or just plain old falure of the detecter.
Mine too. Change the backup batteries inside
Brian in Brighton
