Support brackets for countertop
Steve Schoene
>I'm looking for an unobtrusive solution to support a bar height countertop. It will be placed on a knee wall behind and above a peninsula type kitchen counter and will be about 8 ft. long with a projection or overhang of about 14". I'm trying to avoid the triangular brackets that would easily hold up the outer end. The top will be made from 8/4 curly maple, probably ending about 1 5/8" thick. I've been thinking along the line of a large "angle iron" but have no idea how to find some that would be beefy enough to solidly support the counter.
Re: Support brackets for countertop
Bill White
>What ya want is a corbel or "bar bracket". There are many styles from very simple to greek ornate. Bet you could make them yourself.
Bill
Jesper, Denmark
Jesper, Denmark
>If I understand the "knee wall" correctly as a low wall against the peninsula, can't you just put it on top of the wall? If you are concerned with the strength of the glue joints, use threaded rod to hold the staves together, recessing and plugging the holes facing the counter.
Rick W
>Fastcap makes some steel angle brackets that may work for you.They have several sizes and colors to choose from.
Rick W
>You can have a custom angle fabbed from 1/8 or 3/16 plates welded together to make a 6x6 angle. Run the full length of the counter, it will provide more than enough support.
Clint
Ed Mulligan, Cape Cod
>I saw a neat solution to this a while back. A steel plate slightly smaller than the countertop was recessed into the underside of the countertop. It was screwed to the base and the top. Heavy, no doubt, but no brackets and no sag.
Ed
Dave Mount
>I built a cherry bar that sounds very similar to what you are contemplating, except the overhang was larger. I welded up some 12" brackets with legs made from 2 pieces of 1/4" x 2" bar butted at 90 degrees. To give the bracket strength, I welded two small triangular gussets (maybe 3.5" on the short legs) of 1/8" plate on each side. I put in countersinks for some big flathead screws to keep everything flush. The wall in the kneespace was covered with beaded VG fir T&G; where the vertical legs were (located over studs, of course), I hollowed the back of the paneling to completely hide that leg of the bracket. No one except kids crawling on the floor sees the other leg on the underside of the bar. Very solid, you could stand on that bar.
The secret is the triangular gussets which give the bracket the strength it needs, but you don't notice them (or bump your knees on them) because they're tucked way up in the crotch where the bar meets the kneewall. If you're not a welder yourself, find someone doing welding out of their garage in their spare time, it's a simple thing and shouldn't cost much.
Distortion from the welding may put the finished brackets slightly out of square. No worries, just mount the brackets so the high point is level to top of the kneewall and stick in some thin shims to take up any gaps.
If you can't envision what I'm talking about, ping me and I'll send a pic.
Best,
Dave
what I did: bracket
JKJ in East TN
>Steve,
I had the same issue when remodeling a few years ago. I did NOT want the granite top to give or flex in any way but did not like the looks of the traditional triangular braces. My solution cost only pennies, showed no brackets, and can easily support two moderately sized men or one big fat dancing girl (the latter is projected but not actually tested).
I welded up braces made of sturdy steel channels and welded in a small triangular brace. Note that channel is much stronger than flat steel. I designed the assembly such that the channels were embedded in the top and wall and the small triangular brace was completely hidden in diagonal notches in the wood. I chose to weld up horizontal supports from other steel channels but structural lumber should also work.
I added adjustment bolts to make it easy to align and tension the top under load but shims should also work. After assembly and before the granite was installed, I tightened the ajustment bolts until the top was perfectly level and test loaded it with with a couple of us sitting on top.
The vertical wall was covered by raised hickory panels. The top was granite supported by a sandwich of mdf between two pieces of 3/4" oak plywood, trimmed with hickory. The granite overhangs the hickory trim by a small amount with the overall look of substantial support.
The attached rendering shows how the brace was made. I'll post a photo in the next message.
BTW, I've seen how granite can flex so I made steel supports for other places as well, such as to bridge the dishwasher and disposal gaps.
Re: what I did: assembly
JKJ in East TN
>Kitchen in progress.
BTW, this kitchen has more light than any we've had due lights (not yet installed in this photo) and to the wall of windows that look out over the fields, woods, and hills. I realize it is a cruel punishment to live here but someone has to do it. :)
JKJ in East TN
>Dave, Yikes, it looks like we had almost identical solutions! I saw your message just after creating a graphic and posting mine.
I buried the triangular gussets in notches in wood itself but they could easily be covered with a bit of trim if necessary. I also encountered the "out of square" typical with making such a weld joint without a sturdy fixture but used adjustment bolts instead of shims (which should work just as well.)
BTW, for those who haven't tried it, an inexpensive wire welder will open new horizons of ways to assemble things. I used to spend a lot of time figuring out how to best fasten wooden things together - now I'm just as likely to weld up a bracket from scratch as use fancy joinery or browse the hardware store in search of fastener ideas.
Dave Mount
>Using C-channel is a good idea to get a little more rigidity. I was thinking about using rectangular tubing but decided that 1/4" flat was more than I needed anyway, and it was simpler to bury underneath the paneling.
Ditto on the MIG. Many more options than if you're stuck with wood or pre-fab hardware options only. Not so easy to make a pretty weld, but not very hard to learn to just stick stuff together. Heck, that's what grinders are for, right?
Best,
Dave
Steve Schoene
>Thanks all. Some very good ideas, I appreciate.
