>Just some things I was wondering about. How fanatical are we?
When you are working with various tools, do you put them away as you finish using them or do you just lay them down?
When you finish with the router (or other tool), do you "strip" down and return the bit to storage and the other accessories to storage, or do you just put it away with the "last setup" still intact?
When you make a temporary fixture or jig for some specific task do you save and store it thinking that someday you might use it again, or do you trash it?
Are the aesthetics of your shop high on your priority list? Or is yours like mine a pile of accumulated odds and ends?
So you feel attachment or loyalty to your tools? When they break or wear out do you try to fix them because you feel you should, or do you trash them and get the latest and greatest? So you store the broken ones? Why? Think they might get well or maybe you will realize how to fix them?
Interesting questions.Generally I fight the tendencies to be a real slob in my shop.
I usually just laythem down unless I know it's the last time I'll be using the given tool on the current project.(Power Tools here like drill, router etc)
Last Set-up is always current condition.
I do keep all templates and jigs.
I keep cuttoffs for a few months but will gather up things every so often and give a garbage can full of burnables to my neighbor for his fireplace-I don't have one so it helps us both.
Well when my Dewalt planer developed problems in the ability to raise and lower the carrige, I took it apart to see what pieces were the offending ones. In the end I just bought a new planer and the Yellow Fellow took a ride in a big green square metal box :^)
Yes and No. I am unable to work effectively in a crowded, cluttered environment and became a neat freak. My wife thinks I'm the neatest freak she ever saw. At the end of the day, all tools are returned to their designated locations. Several times a day some are placed in their homes or back on the walls.
The shop vac is used twice per day, especially if I am routing. Sanding is done outside. If I am doing an assembly, I keep my setups in router, jigs, SCMS stops just in case I have to repeat. Otherwise, the bits are returned to storage and jigs etc are put away. The only bit kept in a router is a double flute straight in my laminate trimmer, used for gaining hinges.
I am very fussy about lights. They have no further use when burned out, and I replace immediately. I never throw out a hand tool, and rarely wear out a power tool except for ROS. I pitch these readily. I stopped getting power tools repaired after dealing with Sears. Now I buy other brands. One exception: my De Walt planer has been back to the service center twice in 8 years. The only other exterior maintenance is saw blade sharpening.
>I have a rule in my shop that tolls can be left where they are/were used - but not moved to any other place than where they belong when stored. That way, when too many have accumulated where I work, they get put away.
Routers etc. get put away "as is" - the chance that the same set-up is needed again is fairly high - particularly for the trim router with the round over bit.
"Nice" cut-offs get kept toooooo long. Small stuff is donated to others as kindling.
I buy the best tool I can when I need something, so most things last a very long time. The one exception is cordless drills, which get tossed when the batteries or chuck die.
>I need things in order to work affectively. I always put the router bits back, at least at at the end of the day if not at the end of the task. I have too much trouble finding things in my shop if I lay them down. I can always find them if I put them up.
I usually try to clean at the end of the day except for weekends. On the weekends I get to spend all day in the shop so i will clean up either sunday night or Monday when I get home from work.
I never throw out a handtool and will usually repair a power tool if possible. I don't need the latest greatest, just tools that work well.
I'm so bad about putting things up that I will sometimes chastise myself because I'll put a tool up knowing that I will need it again on that project. It's just habit I guess.
>I generally keep my shop fairly clean. I find it hard to work in a lot of clutter. I don't worry about the last speck of dust or shavings though. I leave the debris until I am done with a particular proccess or I cannot walk safely anymore because of shavings. Stuff like the router stay setup until I am done with a specific task, but that task may go on for days. Once done, I will take the bit out and store it, but that is not a hard and fast rule, and vacuum out all the remaining dust and chips. Shavings and chips don't accumulate very much anymore now that I have a central DC system. Cutoffs are another story and I usually have them coming out of my ears, but that is just because I keep them until a job is done and the last couple jobs have been long ones. I hate to throw anything out while on a job because, sure enough, I will need a little piece of that same material somewhere before the job is done and I would hate to have to mill stuff up just cause I threw what I needed away the day before. Once the job is done I empty the bin so it is ready for the next job; that part kills me and I try to give away what I can but if I don't do it I will be buried pretty quickly. I do generally put tools away in a specific place designated for them so, when needed, I can quickly put my hand to the tool required, without an hour long search. This, however, does not apply to pencils; which seem to disaapear before my very eyes.
Depends on what you mean by fanatical.
Depends on the tool. Some tools I leave out far too long.
The portable routers I strip and put away - or they would remain on the workbench. The router table I leave with the last bit in.
Tough one - I usually make jigs to last. I have a few that probably need to go in the trash.
I have a big pile of accumulated odds and ends - if there wasn't a burn ban in effect, they'd get burned. Currently I have three boxes of accumulated scraps. I'd trash them, but I'd rather not pay to get rid of them ($47/ton). Around here there are no municipal trash services. You have to take everything to the transfer station.
I try to fix them. If they can't be easily fixed, then they go in a box for a transfer station run. As far as latest and greatest, I have a couple of old 1/2" drills, a couple of old circular saws, etc. When they break, I might consider buying another.
>I guess for some of these the answer is "it depends."
Small stuff like bits get put back. Almost everything else is where I left it. My shop hums along like this until I can't find something. Then I get angry, clean up the whole mess, take the pledge to "never again' let things go like that and then immediately return to my slovenly ways.
I save everything until I knock over a pile and things go flying all over hell and creation. Then I'll have a similar sort of experience as described above except it is a sorting and pitching fit. Then I go back to my miserly ways.
How things are set up was never a planned thing. The shop just sort of evolved. Every once in a while I find myself constantly moving something to use something else and eventually end up breaking something in the process. I turn the air blue, rearrange the mess and then go back to my disorganized ways.
I like many others have had an unpleasant experience with Sears tools and have sworn never ever to buy one again. Most other brands are repairable at my local industrial supply shop.
Generally I do repair a tool unless mine eyes have traveled to the sinful pages of tool porn delivered to me in the snail mail or the electronic media. Once my heart is full of lustful desire for more well endowed tools, old faithful's days are numbered. No matter how many times I try to appease the tool gods by repairing instead of replacing, they know the evil that lurks in my heathen heart and send me more porn. Oh, woe is me.
Depends - I sometimes make a jig for a specific task for a project - unless I intend to duplicate the project I pitch the jig. I do keep a few non-dedicated jigs.
Welll - I usually work until I can't stand the mess or I cant find a small tool (like my Unisaw or bandsaw). Then I do clean the shop pretty well and put everything away. I do tend to keep too many "shorts" or strips of wood. About the time I can't add any more to my roll around shelves where I store such items, I try to assemble cutting boards or give them to a friend who is always eager for any lumber.
Nah, I try to keep my tools in top shape, but when the drill battery's quit holding a charge I pitch them. If I see a new tool that has features I REALLY think are important, and that will, in my opinion help me build better furniture, I usually try to obtain it - This seldom happens. I really look for top quality, accurate, well built equipment when I purchase. Not much of a "gadget" admirer. When I find I have a tool I don't use or foresee a possibility of needing in the future, I give it away to a "tool poor" friend. I do try to keep everything I use well maintained, belts adjusted, tables squared up & waxed, with sharp blades, sharpened chisels, all bearings lubed, insides cleaned etc. - a little fanatical in that respect.
>ZZZZZZZZ.....I have always thought that if I could just be a little more organized,plan the project work flow better and have all the necesary tools ready and waiting for their turn instead of scattered all about, that my results would be better.
Total focus on the craftsmanship and quality.
There would be less distractions, and time wasted on searching for lost tools that always hide under the Lee valley bag of stuff I bought... but didn't need.
A fully equipped, dust free shop like Norm's, only without all those expensive free tools cluttering up the place!
I try to put tools away as I finish with them. Most of the time this happens at the end of the work day, but if my bench gets too cluttered to work efficiently, I'll stop, clean up and put things away. I make it a practice to clean up at the end of each day so I don't walk into a mess the next morning. I can't stand working in a mess. I sweep and vacuum and put away the tools I'm done with. I leave the ones I'm working with organized on my bench with the work.
I strip my router down, clean off the sawdust and put the bit away when I'm finished with the task. I never leave a bit in the router. This goes for the router table and other similar tools too.
I save them.
My shop is an accumulation of odds and ends, but I try to keep it organized. I find I work better in an orderly environment. I wouldn't call my shop aesthetically pleasing (except to me), but I do try to keep it orderly.
I usually keep them around for 4 or 5 years (or longer) with every intention of fixing them. After this "ageing process", I invaribly come to the realization that I'll never get them fixed so I end up tossing them.
>in ten minutes I know where the tool IS as opposed to where I LEFT it. Took eight years to get SWMBO to agree with me ! But now we BOTH know where the hammer IS . On my bench (s) at least, everything is within arms reach so hanging it back up is easy.
>#1. Generally I put tools away when I am finished. The question is, when am I finished? Answer, when the part of the project requiring those tools is finished.
#2. Since I usually use a router table (JoinTech), I take out the bit and put it away. If I am using templates, they get put away also. When I use a router as a separate tool, #1 applies.
#3. Some jigs are saved and often discarded later, years later.
#4. Order and neatness, my definition, is what matters, not necessarily cleanliness.
#5. If a broken tool can be fixed easily, that is done. If not, it is discarded. Parts may be cannibalized (nuts, bolts, etc).
I lay them down or put them to the side never know when you will use them next, my big jointer is used more as a storage surface then anything else
Leave it with last set up intact
When you make a temporary fixture or jig for some specific task do you save and store it thinking that someday you might use it again, or do you trash it? save em for a while then when I do a real deep cleaning some get chucked others stay. This is totally arbitrary and depends on my mood or if it was a real awful project I enjoy grabbing all the jigs a burning them
Are the aesthetics of your shop high on your priority list? Or is yours like mine a pile of accumulated odds and ends? My shop is actually fairly organized but any aesthetics is due to function. I really don't care what storage cabinets look like or if my tools are all the same color what matters is do they work and function as they should.
So you feel attachment or loyalty to your tools? When they break or wear out do you try to fix them because you feel you should, or do you trash them and get the latest and greatest? So you store the broken ones? Why? Think they might get well or maybe you will realize how to fix them? I fix what is fixable and pitch the rest.
All this said It only takes about an hour to clean my shop and put everything back.
I work alone now but when I shared a shop things were different if you set up a machine with a special set up you tore it down. never pulled router bits out the next user would do that this works out well since we had a half dozen routers you would get lucky pretty regularlly and find one set up the way you needede it. If you put a special blade on a table saw you would put the regular one back on. clamps got put away when done etc.We all had our own personal areas that we kept how ever we wanted but shared areas were kept pretty organized this tend to keep stress down between everybody.
I think what this post needs is pictures go down and take a pic of your workbench don't move anything just a quick snap shot to show how it looks this moment.
>My jointer. I find the less large flat surfaces in the shop the better. I like the really cheap folding saw horses from harbor freight just got to be carefull not to load them to heavy.
Thanks for your offer dan but found an inexpensive program that looks like it will work.
>Working in a 1 1/2 car garage, I have to stay relatively neat and clean or I won't have room to move. This has also prevented me from accumulating too much clutter. I do normally tend to put most of my tools away when I'm done with them. The exception are some normally used items that are almost always laying on the bench (small square, rule, chisels, pencils, etc). I don't have dust collection, so I may sweep up several times per working session, depending on how much saw dust I created (I sometimes wait for the pile to build up before getting rid of it, then). It does slow me down, but I feel better working in a cleaner, less cluttered shop. I don't take my router/drill bits out after finishing a job, though.
I still have work to do on the shop. The garage is insulated, but I haven't wall boarded. I'd like to get walls up sometime to brighten the space and make things look a little neater. I also have some areas that are stuff repositories which I'm always looking for a way to clean up. I don't believe in having a lot of excess, just what I need to get the job done. I've made almost all of my own benches and stands, and I like being able to see/use them. It makes me feel good to be in a shop that I pretty much built myself (excepting the building itself). My tools are almost all on rolling bases, so I can easily move things around when necessary, which also means I need clean/open space to move around in.
