Screw question
Screw question
Screw question
Sean Troy
>I know this might be a dumb question but what's the best type of screw used to screw OSB to a wall stud? Thanks for any help.
Re: Screw question
Re: Screw question
John Veerkamp
>I just use #8 x1 1/2 or #8 x 1 5/8 coarse thread drywall screws. This presumes you are using 7/16 or 1/2 material.
John
Re: Screw question
Re: Screw question
Sean Troy
>Thanks John
Re: Screw question
Re: Screw question
Larry Clinton At Frankfort (Central)., Indiana
>Sean, my take on your question is that you are going through OSB and fastening (screwing) into the stud. In that case any screw that holds wood will work. If it is a heavy load, I would use lag bolts (1/4 or 5/16"), a medium load - deck screws, or standard wood screws - #10 or #12, and drywall screws for a light load. Length is dependent on thickness of the OSB, wall covering and the stud width. IE: for a heavy load mounting 3/4 OSB on a 2X4 wall with 5/8 thick drywall, I would use 4 to 4 1/2 long lags (if not countersunk). Lighter loads do not require the maximum length, but should enter the stud at least 1 1/2" for good holding power.
