Dealing with 2x goo?
wilbur
>I am making a utility workbench with 2x material. I've got the base put together, which used kiln dried SPF 2x4's. For the top I found some good quality 2x8's that are green Douglas fir. They've been sitting around for a few weeks now, and seem to have come to equilibrium as far as drying, but I've noticed that there is a bit of "goo" coming out of the boards. Obviously, it's pitch or sap.
Is there a good way of getting rid of this stuff so that I could reduce how much of the goo gets onto the blades of my saws and jointer?
Re: Dealing with 2x goo?
what is normally done
Bill Tindall, E.TN
>Kiln drying "sets" the pitch. In fact what it does is boil out the volatile components leaving behind the solid resin which does not ooze. If you have some place that gets hot, put the planks there for a couple of weeks. Otherwise you will live with the problem.
JKJ in East TN
>Wilber, some softwood boards, will bleed pitch incessently unless properly kiln dried. It is common in the industry to run a kiln at a higher temperature (typically 160 deg F) for a time at the end of the drying program to "set the pitch". I understand this drives out volitle components of the resins to harden and prevent bleeding.
I think the pitch will eventually harden by air drying but I have no idea of the time involved - it may take a few years. You might try searching the archives of some of the sawing/drying forums and asking there if you can't find an answer:
http://www.forestryforum.com/board
http://www.woodweb.com/cgi-bin/forums/sawdry.pl
Another good resource is the Knowledge Base collection on the Woodweb:
http://www.woodweb.com/KnowledgeBase/KBIndex.html
I typed in "set pitch" and see the first article concerned Doublas Fir.
Re: what is normally done
wilbur
>I read up on kiln drying and setting the pitch. It looks like temperatures of 160-180 are needed. The hottest place I have is my garage, which is where the boards were sitting for the past few weeks already, and I don't think it gets up to those temperatures.
If getting rid of volatiles is the issue, would wiping the face of the board with something like mineral spirits alleviate the problem? This is not a fine furniture project, so I'm not too concerned with future seepage. I just want to be able to mill the boards without pitch getting all over everything.
Your Driveway Kiln
>Wilbur,
Wrap your 2x stock in black plastic with sealed ends stickers between the boards out in your driveway or other full-sun spot. 2 sunny days' treatment ought to do it for you.
mm
Mike Fitterling
>Unless you want to leave the bench raw, then make the first step in finishing a coat of dewaxed (if something else will go on top) shellac. Shellac is commonly used before painting to contain the pitch that sometimes exudes from woods like southern yellow pine, et al.
If you want to leave it raw then the other suggestions ought to help.
Good luck,
Mike
Gary Evans Tallassee, TN
>Hi Wilbur,
If you have an attic space that you can access, it should be hot enough to set the pitch. As someone else stated, a couple of weeks ought to do it.
If your boards are dead green, the black plastic wrap on the driveway might be preferable. If they are already somewhat dry(20% or so,) then the attic shouldn't hurt them.
Gary
I'd Take A Different Approach
>Good Evening Wilbur,
I doubt a little goo will hurt the jointer and table saw blades very much. Blades are quick and easy to clean, so I'd build the bench and then clean the blades. If I had much more ooze on the top, I'd cover it with masonite or plywood. If it oozed out of the board ends, I'd edge face with whatever is handy. After waiting decades for the tree to grow, I run out of patience. :<)
George
Just put them in my car! That will set the pitch
Mark in B'ham
