crown molding chart
crown molding chart
crown molding chart
Ken Miller
>I'm in need of some help with cutting crown molding. Is there a chart that anyone knows of that tells you the bevel and miter cuts for various angles inside and outside corners? Actually I have one inside corner of 35 degrees, one outside corner of 40 degrees and the rest are inside 90 degrees. With the inside 90 degree corners I'd prefer not to butt them together and cope as I have never tried coping anything before and I'm affraid that i'd be there all day. Any other helpful hints would be much appreciated as well.
Re: crown molding chart
Re: crown molding chart *LINK*
Eddie Pacheco, San Jose, Ca.
>Just a quick search on "crown molding chart" turned up this little tidbit of info.
I would also suggest that you not rule out coping. After the first 2 or three it doesn't take that long to do and minimizes a lot of grief in matching angles. Saves molding material too.
Crown molding chart
Other advantages to coping....
John in New Mexico
>The joint won't open as much as the wood dries (not a big deal if you're using mdf or plastic molding). I also find corners that aren't quite 90 to be a lot easier to deal with when coping than mitering, since you can cheat a little and relieve the back of the joint and persuade it a little. Just miter the molding to get a nice clean profile line and cut up to it with a jigsaw and a medium or fine rasp. Its really not too difficult.
John
frank shic
>If you go to the trim department or miter saw section of home depot, there's a baby blue book called Installing Crown Molding like a Pro which has all the angles that you need to miter the corners. However, having used this method, I have since gone back to coping the corners. It's a lot more fun and you can easily justify the purchase of a new tool like the Collins coping foot or the EasyCoper. The corners close up much more tightly. You should also consider buying Gary Katz's video on installing crown molding - a BARGAIN compared to what he teaches. He starts from the most basic concepts and advances on to installing crown on vaulted ceilings and even kitchen cabinets.
Ken Miller
>Thanks for the replies. The link and advice will be most helpful, though I'm still debating on the coping deal.
frank shic
>Ken, I should have added that mitering the corners on MDF crown molding is perfectably acceptable. That's what many of the professional trim carpenters do and that's what Gary Katz recommends in his DVD since the coped corner on MDF is extremely fragile and can easily crumble when you try to fit the corners together. Coping works better for baseboards and HARDWOOD crown molding.
Rob Hix - King George, VA
>I put up MDF crown molding throughout my house and I have had no problem with coping the molding. You do have to be careful, but you will learn that quickly.
Also, look in the archives of Fine Homebuilding. There are a couple of articles in there that are life savers. I cannot remember the article title or month, but there was one really helpful one. When coping, the last piece you put in is usually coped on each end. Although not extremely hard, it takes practice. This article showed a method to avoid the dreaded final double coped molding. It was really cool.
Rob Hix
mark lepore
>I found a great chart with all of the different possible angles on Delta.com
Re: Crown molding install a success
Ken Miller
>I just wanted to thank everyone for their invaluable information about installing crown molding. I did buy mdf molding and decided not to cope. I used the information found on the website altereagle.com which was given to me by Eddie Pacheco. I preferred cutting the molding flat and using the chart on the website as the beginning of finding the correct bevel and miter. After a few trial cuts for each corner I was able to get good fitting joints - at least nothing so bad that a little caulking couldn't make look perfect.
