ADVERTISE HERE - FREE TRIAL
working with cherry
working with cherry
working with cherry
ken erickson
>I was at my favorite local wood supplier this weekend when I came across a gorgeous piece of cherry with a lot of figuring � almost like birds-eye maple. The only problem with it was someone left it out in the sunlight with items on top of it so now it has sever photo marks on it. The price was right so I bought but now I�m wondering what�s the best way to even out the markings.
I don�t want to use a dark stain � I figured it would hide the figuring.
I�ve never worked with cherry before but know it will darken up with time and light exposure and I would like to prevent most of that if there is way to accomplish that goal.
Any ideas to even out the photo markings and prevent it from going totally dark?
Thanks,
Ken
Re: working with cherry
Have you tried sanding them out?
John in New Mexico
>I've been building some paneling out of African mahogany, and it changes very quickly in the sun (especially at my elevation). But it seems to sand off pretty easily too.
John
(We'd love to see some pics when you build something out of it!)
Re: Have you tried sanding them out?
ken erickson
>I took a block plane to a test piece and the surface appeared to be lighter. I then applied some mineral sprits to the surface (the figuring just jumps out at you) and for a while it looked OK but then the MS dried to a point where you could see the photo marks coming back into view.
>Good Afternoon Ken,
I have worked pretty much with cherry in my last few projects. I found that the difference in color disappear with planing and sanding.
George
Let nature do it for you
>Selective staining is just going to become more noticeable as the color of the cherry naturally darkens over time, which it will do regardless. That darkening effect you see doesn't go too deeply into the wood, so maybe a pass or three through the planer will get you back to scratch. If not, I'd just wait and let the color mellow naturally. I wouldn't put too heavy a film finish on it, because O2 adds to the darkening effect.
I'm curious what would happen if you suspended something over the darker areas to keep the sunlight from getting to them, and just let the lighter areas get darker at a faster clip until they're about equal? I've never tried this -- and I don't generally like fussy workarounds -- but the results would be interesting to see.
Ellis Walentine, Host
>Try leaving it out in the sun for a while to even it out. Sun lamps work too - though they do look at you sort of strange when you bring wood into their tanning booths :).
ken erickson
>I don't think a 9' board would fit inside one of those machines.
I think I'll let it sit outside in the sun for a few hours see if I can even out the marks.
Patience
>You'll need more than a few hours. Maybe days, maybe even weeks. But I agree, rather than removing the darker areas, allow the board to even out with sun and 02 exposure. If it's that good then it's worth the effort and patience.
Tom
Cut a couple of feet off and send them to me
Don in Northern Arizona
>then it will fit.
Don
Jim Dillon
>Ken,
I was recently working with some quartersawn fir that got "sun-burnt" in areas while on the garage floor near the door. I was very surprised how difficult it was to sand out the discoloration when I finally went through my normal sanding procedure with a ROS. If your wood is oversized, I would consider planing (if you have a planer) just a tad to quickly get rid of the discoloration. Otherwise, I like the advice by others to try to equalize the discoloration by setting the wood outside or whatever. With cherry, time may indeed heal all discoloration, but then again it may not. On-the-other- hand, if these areas of discoloration will be out-of-sight, I wouldn't worry too much. Good luck.
Jim
ken erickson
>Jim,
Unfortunately the wood is not oversized but finish 3/4" and the design is dimensioned for 3/4. Fortunately most of the �damage� is on one side and I have enough of the wood to work around the area. It just that I hate wasting that must of good wood, especially cherry with that much figuring. I just hope the dark grain patterns that are visible now will be still visible when the rest of the grain gets darker.
-Ken
Dan Donaldson
>From the experience that I have had with cherry, if you don't stain it and just let it darken naturally, the figure just gets better with time. Should look great.
ken erickson
>What finish would you recommend?
Depends *LINK*
Dan Donaldson
>Depends on what you make out of it. If it is not a high wear item like a tabletop, I like a bit of oil to pop the grain and then shellac. If it is high wear, then some type of varnish or poly is probably what you want. I am attaching a link to a small chest that I made a few years ago. It has since darkened several shades, but the figure is still there very nicely. Yours is probably more figured than this, but I would expect the same.
Cherry chest
Re: Depends
ken erickson
>I'm working on a wooden gear clock design by Clayton Boyer. The gears are all cut from Baltic Birch ply which I plan to finish with poly but I haven't decided what would be best to finish the cherry with. I've used wipe on poly and spray lacquer for previous projects with good results.
