>I want to veneer some small drawer fronts with figured ash burl to go with the Chester County spice box I am making from my Steve Latta course at Marc Adams School. This is my first veneer attempt. What glue should I use? Franklin makes a Cold Bond veneering glue. Was thinking of hammer veneering and clamping with cauls.
Please recommend a very decent small shop vacuum press. I'd like some pretty good quality but, make pretty small stuff - no big tables.
>For hammer veneering, you want hot hide glue. There is plenty of information about this process in books and on the web. It takes some practice to learn, but it will be easy on little drawer fronts like those on your spice box.
Vacuum Pressing Systems is a good bet for quality press components, including vacuum pumps. I don't recommend the venturi-type systems that run off your air compressor. Compressors are loud and use a lot of electricity. Regarding the size of the bag, you can buy any size bag that suits your project size. For occasional use on smaller projects, the less expensive vinyl bag will be fine.
>I have had very good luck with Vacupress. They have a good forum where you can ask questions. Their small pump has served me well so far. I use UniBond 800 glue. I have also used liquid hide glue for smaller stuff. The UniBond is nice because it is a rigid glue and resists creep. Good luck with your project. I'd love to take a class from Steve. You'll have to let us know how that goes too.
>I use titebond for veneering. I tried the cold press glue and didn't like it very much it seemed a little thicker and to have less open time. I've used uni bond and it works well also titebond is less expensive and is locally availble. cold creep really isn't really a problem with veneering as much as it is with lamination type work. one of the really nice features of uni bond is that the open time and pressing time is adjustable so if you have a real complex or large project you can give yourself more time.
For small flat work clamps and cauls works real well and is cheap.
>I don't have a vacuum press, but now is on my wish list.
I have veneered and laminated many things using Titebond and cauls and c-clamps. Ror cauls I like to use pieces of countertop with plastic laminate (Formica) on one side. I get "sink cutouts" from a friend in the countertop business and cut them up. (Many shops throw them away and will give you some.) I find the glue will not stick to the plastic. I also like to use larger pieces that have bulged or deformed uniformly into "domes". I assume this helps apply pressure toward the center of larger pieces where the clamps won't reach. If the convex side of the dome is on the side without the plastic, I just cover them with a piece of polyethylene to prevent the glue sticking. I made 18" by 26" panels this way with no trouble at all. Used every clamp I had, but no trouble. Use "matching" domes, they cancel each other out and the piece comes out flat.
Small drawer fronts like 2" by 10" would be easy. Two pieces of flat scraps as cauls and three or four clamps. You can use clear packing tape on the cauls to keep the glue from sticking.
PS. If you think the part about keeping the glue from sticking sounds "fussy" its not. If your veneer is then and porous, glue might ooze through it and glue the face side to the caul. There will be squeeze out. You really don't want to glue the whole thing together into a big sandwich. DAMHIKT Because the plastic retards drying, I would leave the clamps on much longer than the clamp time on the bottle, a couple of hours, maybe over night.
