Power Washed Deck question?
>My friend power washed her deck. It's aging treated pine. Now she says it's "fuzzy". She wants to stain it. Is there an easy way to clean up the fuzz and get a decent appearance?
Re: Power Washed Deck question?
Jennifer@Indy.USA
>The fuzz is most likely from holding the tip of the sprayer too close to the wood while cleaning it. Same thing happened to my neighbor, by a "professional" she hired. The deck finish will make it look less fuzzy, but I would suggest a double application of the stuff. My neighbor only used one.
Jen
Sanding
Jim in Burlington On
>I'd hand sand it with drywall screen on a pole. Sounds harder than it is.
Funny you ask...
Denis Ch�nard, Orl�ans, Ont.
>I did the same thing in the last few days...
My deck (cedar), build for my wedding three years ago, never got finished for a number of reasons. It was gray all right...
So I went to work. Power washed the whole thing, and some areas became "fuzzy". I then treated the deck with a deck cleaner (Deckswood), concentrated formula, and the deck came back close to the original wood color.
Except for the knots, which remained gray. And the pressure washer ate at the earlywood and made many areas "chippy" or rough. I had no choice but to run a sander to clean that up. Not fun to do a 18' x 17' deck with a random orbit sander (especially the built-in benches)...
It's all done now, so tomorrow I will be applying Sikkens Cetol SRD to the deck and the children's play structure. Should look good...
DC
Rusty in Alberni
>Rent one of the floor sanders.Much easier
They Won't Rent One To You
Dave's Not Here
>Around here, if the rental place knows you're going to use it on a deck they won't rent you one. Too much chance that the screw heads or nails will damage the sander. BTW, even if you don't tell them what you're going to use it for, they will check the machine for damage when you return it.
