Antiquing Pine - FWW Article
Robert R Clough - Thorncraft
>Recently I read and re-read Wisshack's article on "Best Finish for Pine" in FWW, Oct., '07. I enjoy the look of antique pine or even weathered pine but I have never been able to achieve the look on new stock, but I am now optimistic. However, I have a question: if Polurethane cannot be used because Zinsser Shellac is waxed, why not use de-waxed shellac so that polyurethane may be used? Are there any stains other than Olympic that would do as well?
I ask this because I always use spray polyurethane and have not seen spray varnish. I am apparently incapable of using a brush well, thus the spray cans. Only once have I ever done good work with a brush; that was refinishing a Shaker Rocker back in the '60s.
The article is well written, succinct, and complete (were it an historical article I'd say closely written).
Re: Antiquing Pine - FWW Article
Tony - Memphis
>I use the Zinnser Sealcoat under poly all the time. I usually use the shellac to seal before I glaze. No issues at all. As for the stain, its a subjective thing. Minwax has a color called Pumpkin Pine I think it is that looks pretty good to me. The samples at Home Depot and Lowes are usually a pretty good source of relative colors. Best to experiment.
Tony
Dave Bair, Eaton Rapids, MI
>The waxed Zinsser adds a good bit of it's own brown/orange color to the mix. You could follow the waxed shellac with a coat of the waxless Sealcoat and then poly.
