Sealing deck board end grain
Bart Goldberg
Bart Goldberg
>I'm visiting my brother's beach house in Fire Island and I noticed that most of the houses out here all suffer from deck board rot near the board ends. I suspect that no one is sealing the deck board end grain when replacing deck boards. I was wondering how effective Anchorseal would be for this application. Would it be able to last a long time, or would a shellac based product work better?
Thanks
Bart
Re: Sealing deck board end grain
John in New Mexico
>I think anchorseal is your best bet, it lasts a lot better than I expected on Ipe of all things, but be warned, it'll probably look a bit different that whatever the rest is treated with (or if it isn't treated). Also, be careful not to drip it on the deck surface, as its pretty waxy and no other finish will penetrate or stick to areas that have anchorseal on them.
John
>Bart,
Anchorseal is WORTHLESS for your application because the wax contains an emulsifier to hold it in suspension. As the result, rain will simply wash it off because it "reimulsifies" in the rain water.
If you want to protect the end grain, you'll need to soak those ends in something like spar varnish or similar sealer thinned a bit to promote penetration, and made to resist UV and weathering.
mm
Howard Norman-Prescott, AZ
>I have an Ipe deck that has Anchorseal on the ends for a year and a half. Has held up well.
Howard
