drying cherry slabs
drying cherry slabs
drying cherry slabs
peter bunnett
>I have about 20 cherry logs ,12 feet long 10" to 20 " to bandsaw to 1.5 and 2" thickness. I'm told cherry wants to twist and so I should reconstitute the logs ,sticker and steel band or I'll have a twisted mess. I would prefer to stack and sticker,then cover with a steel roof and weight down with concrete blocks.Icould put this in a shed but would rather not dedicate the space to something that could occur out side .Suggestions or previous experiences please.Peter Bunnett
Re: drying cherry slabs
Dale Lenz
Dale Lenz
>Proceed as you plan. The lumber from the smaller logs may cup some, but with your thickness you will be sawing, cupping might not be as severe as 1" lumber. Cherry dries fine, if proper stacking adhered too. Box the pith or as sawmillers say, "box the heart" and use for something other than furniture lumber, makes good firewood.
my experience
Bill Tindall, E.TN
>I have dried lots of cherry. It has one feature that makes it different from most woods. Its sap wood must shrink an unusual amount relative to the heart wood because a board with sap on one side will invariably cup, even if 8/4. One can mitigate against this fact by concentrating the sapwood in some outer boards. For normal thickness of sap ring this may decrease log yield some. Additionally, the heart/center of the tree (approx inner couple of inches or so) typically fractures upon drying. It is not unreasonable to saw the log such that there is good lumber on either side of this center and just let it bust. I can be ripped out later. Or if the log is clear to the center keep turning it as it is sawed, not such an easy task on a band mill which is slow anyway, and concentrate this center into a 3 x3 or 4 x 4 which will be useless.
Stack it well, cover to keep the sun and rain off it, and all will be well. Top one or two layers may warp some so put the junk up there and the good stuff at the bottom and middle.
Cherry gives up its water easily. If you live up north it is getting cooler such that it will less a problem cutting it now than here where it has been and will be 90's. Ideally, I like to saw lumber for my use after it is cool so it does not dry too quickly in the stack, or mold on the way to the stack. If you haven't cut the trees yet I would wait a month. Where ever you live it will be ready for the kiln next spring if you keep the rain off it this winter and it has good air movement.
