How to cut spline groove?
Al Stokka - Cambridge, Iowa
>I was all set to cut a pair of spline grooves in a 90� corner joint mitered at 45� made of �" thick material. Made a fixture to hold the parts so I could cut the grooves on the table saw. Lo and behold, I cannot locate a blade that will cut a truly flat-bottom groove. Tried evey one of mine. They all left a tringle of wood either in the bottom corners of the groove or a hump in the middle. Went to an industrial saw blade supplier and bought what I was told would do the job. No dice. Went to Woodsmith with the same result. Returned both blades and bought a 3-wing router bit.
Is there a better way the a table mounted router? Know of a blade that will cut a truely flat bottom 1/8" groove?
Al
Re: How to cut spline groove?
>Just a thought - how about a biscuit joiner?
>JL,
Thanks for the idea but, I have no bisquit joiner. Haven't even looked at the cutter. I wonder, though, are the slots square cornered? Seems to me that the bisquits have a radius and I would assume the cutter does as well. Don't know.
Al
I know and I would tell you, but.....
>you gave me grief about my 12' square doors. I made them work, too. Nah, Nah, Nah.
Actually there are saw blades that will do what you want. I think they are called Triple bevel blades. They ave the standard alternate bevel teeth that are pointed on the left and right and a third tooth that has a flat top with the corners nipped off. Most of the blade makers have them (I am sure Forrest does and Freud also I think.) Look for blades advertised for cutting box joints.
You must be cutting joints in a miter like in a picture frame and leaving them showing. My first assumption was you were cutting a long miter in the edge of a piece like for a table leg. In that case the spline would not show and I was wondering shy you cared. Then the other uses dawned on me.
I have a three wing cutter that mounts on a shaft with a guide bearing for a router. It would work fine if you are cutting the spline into a piece like a picture frame or flat panel. If you are trying to run splines through the corner of a box you may need a saw blade.
If you have a dado set, check the blades in that. I have an ancient stack dado set and it's blade cut flat bottom slots.
Re: How to cut spline groove? *LINK*
Jim Dillon
>Hi Al,
I've had excellent luck with Forrest's custom FTG blade. Got the idea from Yeung Chan's book (superb book IMHO) on joinery using power tools where he recommends a FTG for joinery (but no brand recomendation was given I think). Couldn't be more pleased with the blade and I try to save the blade for joinery work. If you are so inclined, go the the link below and scroll down to the Customized Woodworker-2 blades where you will see a 1/8 inch blade. Good luck.
Jim
Forrest Custom FTG Blade
Re: I know and I would tell you, but.....
Brian in Sandusky, OH
>I had the same problem, and if you want to use the tablesaw (which is best), then you do indeed need to buy a special blade.
A triple chip blade will not work, as they cut a tiny notch along the bottom of the groove.
If you plan on doing a lot of splined miters or other splined joints where the edge is exposed, then I recommend having a blade custom ground.
I called the friendly guys at carbide.com and had them custom grind a blade for me.
The blade was an Amana Prestige, and they charged me something like $10 to grind it flat.
Works perfect...seamless joints.
There may be options now for a perfectly flat profiled blade, but when I did my homework on this about 2-3 years ago, I remember finding nothing, otherwise I wouldn't have bothered with the custom grinding.
Patrick Schupbach
>Most quality rip blades should cut flat bottomed grooves. Your slot cutter should do the same.
>Good Evening Al,
I use my Freud dado blade. Flat as yesterday's ginger ale.
George
Bill Sams
>Not trying to be glib, but how about just squaring across the cut and use a sharp chisel to pare out the waste and beveling downward just a bit to avoid the spline riding the center.
Dale Lenz
Re: Al....
Dale Lenz
>How many spline, key slots you gonna make, now and in the future?
Me too
Jeff Weaver
>Exactly how I do it. 1/8" groove, dead flat bottom.
Not all of them do.
Mark Harrison - Brisbane, Australia
>Many blades these days have ATB grind.
>Barry,
Are we foing to see pictures of those 12' doors? I hope so. It would be a first on Wood Central and probably a first on Al Gore's internet.
Yes, spline for picture frames, flag cases, boxes.
Funny you mention Freud. That's the main brand that the industrial dealer that I mentioned sells. He sold me a LU84M011 (I think) saying it would do what I wanted. Being unconvinced, when I got the blade home and mounted on the saw I set up a dial indicator and measured, as I recall, .010" radial difference between the beveled teeth and the flat teeth, with the flat teeth being shorter. I called to confirm that I could make a test cut and still be able to return the blade. Making the cut produced a kerf with an obvious hump in the center.
The Woodsmith Store sold me a Freud Glue Line Rip blade (don't recall the number). It produced the opposite problem - left triangles in both corners. I returned that blade also and bought the 3-wing router cutter.
I haven't tried the router bit yet but, with it's rather short shaft, I may have trouble cutting a spline groove in the desired location on a wide board. For instance, two splines evenly spaced on the corners of a box 5" high. That's why I opted for the saw blade...more flexible setup.
Oddly, I have a Forrest Dado King that hasn't been mounted on the saw since I bought it about 3 years ago. I'll have to see if using only one of the outside blades will do the job.
Al
Al
Re: Freud blade ID
>As soon as I clicked "post message" I spotted that paper on which I recorded the Freud blade numbers. The first blade (that would supposedly produce flat bottomed kerfs) was LM74M010. That blade measured .010" difference between the beveled and flat teeth. the flat teeth being shorter.
The glue line rip blade was LU84M011. I didn't measure this blade but, it left obvious trinagles of wood in the corners of the kerf. I'd estimate about .010" in height.
Al
>Jim,
Kinda pricey for my intended use but, I do appreciate your input and will keep the Forrest blade in mind.
Al
>Patrick,
I appreciate your thought.
Not to be contrary but, can one do much better than the Freud Glue Line Rip blade? As I mentioned, that blade has flat teeth that are.010" shorter than the beveled teeth and leaves a triangle centered in the kerf.
Al
>Bill,
If I understand you suggestion, you propose cutting the slot and then squaring it up with a chisel? An eight-inch wide chisel? Might exist but, I haven't seen one.
Al
>George,
Funny, I have a Forrest Dado King that hasn't seen my table saw and I bought the blade about 3 years ago. I'll mount one of the outer blades, if I can find the set, and see what it can do. Thanks.
Al
Re: Al....
>Dale,
I have 16 spline slots waiting to be cut right now. In the future? Who knows? Having the ability to cut flat bottom kerfs would also allow me to cut rabbet joint easier/cleaner on the table saw. I make rabbet joints on small boxes of, usually, �" material quite often. With my current blade(s), I have to clean up the bottom of the kerfs before assembling the boxes.
Al
Go to Sears.
Ray Thompson - Middletown,IN
>I really hate to make that recommendation but I found a rip blade with flat tops that cuts a nice flat bottomed slot. It isn't exactly 1/8 but I can live with it.
Ray
>When I bought my Forrest WW II blade, I bought the 1/8" one rather than the 1/10" one thinking it might be useful for making spline joints. NOT! At least not where the ends are exposed because of the ATB grind.
I just fond an ad for Forrest blades (in every FWW)and they make a Custom Woodworker II advertised for box joints, etc. That blade would do what you want (If it cuts as advertised) but if it is $118 it a bit pricey.
You were lucky they let you make a test cut and take the blade back. Often its a pig in a poke.
I have the pack rat gene and have every blade I have ever owned. I would take one to a custom shop and have it reground to cut flat bottom slots if I could get it done for ten or twenty bucks. OTOH, my experience with sharpening shops has been abysmal. (Many years ago I took a hollow ground trim blade to a shop and they set the teeth. They had never seen a blade without set, so they added some, a lot. I keep it to make my chainsaw feel better.)
I finally had my ancient steel dado set sharpened and they set the teeth. They no longer cut 1/8" kerf. Apparently there is difference between using a saw blade and sharpening one. Different mindset, but I digress.
Rummage up your Forrest dado set and see if the blades in that won't do the job. (Then you can take the slot cutter back and pretend you got a "discount" on the dado set. Pat yourself on the back for having had the foresight to buy and store it until the right moment came along. Money well spent. I love it when I find I have what I need. The only thing better is a good or even lame excuse to buy a new tool.)
Dale Lenz
Re: Al....
Dale Lenz
>I cut literally hundreds of near perfect flat bottom splines/years by using a Forrest Dado King. Occasional I have chip out problems where the blades exits the cuts, jig, operator error. Prior to purchasing the Dado King, I was informed the two outside blades have a .015" hook on the outside edge of the blade. The Forrest Rep. told me, the hook is to reduce chip-out in plywood. I ask Forrest to grind the hooks off prior to shipping to me, as I don't use much plywood, they did, no extra charge. So...I have a 250~300 dollars dado cutter. Did I make a good investment, I think so. BTW, I have an 1/8" chisel and have cleaned out the bottoms of 1/8" spline slots, years ago.
Bill Sams
>Al, maybe I have misunderstood what you are doing. I assumed you were cutting 1/4" kerf across a miter, with the two mitered pcs clamped together,(as they will be in final assembly), vertically in a jig, which rides along the fence of the table saw. If this is so, you now have, like you say, an approx 8" long x 2" deep x 1/4" slot which now you will glue in a similiar or contrasting wood spline, which will be trimmed after the glue sets up and the spline only exposed on the outside of the frame.
So even though your blade does not cut a flat bottom in the kerf, if you square across the 3/4" dimension and mark at the base of the kerf of each individual pc, then use a 1/4" chisel to pare out the "v" that the saw blade has left. So in this regard you just need a 1/4" wide paring chisel, slicing out the waste.
So if you still need an 8" wide chisel, I am totally lost, and I apologize for misunderstanding your initial task at hand.
Regards
Freud LM72R
Curt Harms
>Says it has a flat top grind. I have a Freud 24 tooth ripper that does what You want nicely. I'm not sure if it's the LM72R or not. Wasn't expensive, I think $30-$40.
LM72R Industrial Perma-SHIELD� Coated Rip Blades
* Freud's LM72M Industrial Rip blades are the industry standard for glue line ripping of hard and soft woods from 3/4 to 2-3/4 inch thick.
* Featuring extra rigid blade bodies and flat top MicroGrain carbide teeth, these blades give the straightest, smoothest cuts and perform longer than any blade in their class.
* Thick MicroGrain carbide tips
* Laser cut blade bodies and expansion slots
* Kickback reducing design
* Tri-metal brazing impact-resistant tips
* Perma-SHEILD� coating guarantees less working friction and less resin adhesion while preventing the development of rust
* Covered by Freud's Limited Lifetime Warranty
