display lighting
display lighting
display lighting
Bruce Mack
>I'm making a small stand to display a friend's bas relief carvings. The base of the stand is 11x12 inches. The carvings are 4x5 or smaller. I want to have an irregular foreground of round and jagged shapes, cut from pine and painted dark brown or gray, above which will be the small platform for the carving. I want a couple of small lights hidden in the foreground, shining on the art. Puck lights are too large, I think. Has anyone dealt with a similar display problem and found a source for small lights, reflectors, and transformers? Thanks.
Re: display lighting
>In a word, no, but how about this idea? Make the base of this stand of glass or translucent plastic and put a regular light fixture under it. Build your irregular shapes around the perimeter, leaving a space for light to come up all around the platform through the glass floor.
There are also currently a lot of nifty little LCD lights in various configurations that you could use for this. Micro-Fence uses one on its new laminate trimmer base to illuminate the work. You'd have to turn it on and off manually, and the light is that eerie blue color, but that might work well for bas relief carvings.
Let us know what you find out.
Ellis Walentine, Host
Bruce Mack
>Thanks, Ellis. I've been looking at model railroad sites for lighting supplies, and see LEDs of various sizes sold with transformers. I could buy these and take the loss if it did not work out. I like the idea of a transparent base too. I will let you know.
Re: display lighting *LINK*
Jim Dillon
>Bruce,
Pegasus Associates Lighting has a good assortment of lights, but I don't know if they have anything that would fit your needs. Two other possible sources are http://www.tasklighting.com/ and http://www.superbrightleds.com/led_prods.htm. I've only dealt with Pegasus and had got excellent advice and service. Good luck.
Jim
Bruce Mack
>Thanks. I'll check it out.
Smoke and mirrors
Gary Evans Tallassee, TN
>Bruce,
If there is enough room under the platform for a light, you could leave the front wall open and place a mirror against the back of your foreground at the necessary angle to reflect the light to the proper place on top.
Gary
