ADVERTISE HERE - FREE TRIAL
Anybody know anything about these old tools?
Gary Evans Tallassee, TN
>I looked today at 3 old woodworking machines, at least two of which were built by a company called Bechtold Engineering. One is a double headed shaper with a power feed. The second consists of two 4' long rollers, one of which is powered. The third, which I couldn't find a name on, is a long machine that has a power feed, a heater on either edge at one end and a couple of slotting cutters on each edge on the other end. I've found a couple of references to Bechtold being in the laminated top machinery business, but that's all I've found so far. I could get the machines, plus a bunch of shaper cutters for $350, which might be worth it just for the motors and the cutters. There are at least seven 3PH motors of various sizes, including two 5HP motors on the shaper.
If anybody has any info on these type machines, I'd be interested.
Thanks,
Gary
Re: Anybody know anything about these old tools?
gil
>Gary,
I have no information on those machines but the Old WoodWorking Machines site probably will. Go to http://www.owwm.com/ and ask them.
gil
>Thanks gil,
I checked over there, but the only reference they had for the company was a couple of patents back in the sixties for a sliding table saw.
I have found out that a pinch roller is used for gluing up laminate. The pressure causes the glue to set up.
I still don't know what the long edge groover with the heaters was used for. Why would you have a 14' long dedicated machine to cut a 3/8" groove on either edge of an approximately 12" wide board? And what would that have to do with laminate work?
Thanks again,
Gary
Al Stokka - Cambridge, Iowa
>Gary,
When you mentioned a groover/heater in your original post I thought of commercial office desk. Those desks are often edged with bull nose vinyl trim which, I assume, is a "T" with the top of the "T" being the bull nose and the bottom being a barbed section. The lower, barbed section is pressed into a kerf thereby holding the edging in place. Now that you say the machine cuts a 3/8" groove, I'm not so sure. Maybe pry the edging off your desk at work and see if it's 3/8"?
Seriously, just trying to help you figure out the machines use.
Al
>Thanks Al,
You could be correct, and those may be 1/4" slot cutters instead of 3/8". I didn't measure them. I just can't figure out why you would cut slots on both edges of a board, unless it was dedicated to making shelves with laminate tops and banded edges.
Gary
