>It is time to do another Bondo job on my old work truck. I have learned since doing it before that fibreglass resin doesn't adhear well to bare steel especially if there is some rust pits. So I am wondering if I should prime those areas with an automotive paint primer or dab some System 7 epoxie on the bare metal areas before using the much cheaper polyester resin with fibreglass cloth to cover the wounds?
>Donno how old the truck is, but replacement panels are usually a heck of a lot cheaper than trying to mickey-mouse fiberglass to rust - that's a guaranteed repeat repair.
>The truck is 34 years-old and the last year that they put a stick shift in a van, so I am keeping it. 3 speeds never fail like automatics do.
I just priced a gallon of grey primer here in Princeton, B.C. and its C$74 per gallon! I think I'll wait till I get down to Bellingham to buy the stuff.
I have a 1975 flat bed truck that had badly rusted holes in one door. I welded a piece of sheet metal on the area using a wire welder then ground and painted. It doesn't look all that pretty but it is certainly solid. Perhaps this is an option for you. Welding the thin steel was not difficult - I basically used a series of small tack welds.
>I did some glassing on a car years ago. Advice then was to drill a bunch of small holes before applying resin and cloth to the surface--kind of like lath for plastering.
I thought that in the intervening years they'd improved Bondo type body putties to the point they would stick well to metal. Maybe it has to be really clean bare metal and the rust you've got is too much for it. Maybe the cloth/resin overlay would work better.
I think I'd tackweld on a larger metal overlay and bondo the seams as smooth as I could.
>I only have a stick welder and I don't think it is suitable to weld sheetmetal. However I might try to get some stainless steel rods as they weld at a lower temperature. Anyway, I got a big area that needs fibreglass. Previously I riveted metal to the body in some areas, but I learned in the meantime that it is agood idea to smear heavy grease between the metal so it wont rust between the metal plates.
You can buy a cheap ($200-300) wire welder at a big box store, farm store, etc. These will work with flux core wire so you don't even have to mess with gas tanks. If you haven't used one, they are more or less "point and shoot". I reach for the wire welder for most repairs and save the stick welder for thick steel.
I'm no expert on this, but something tells me SS rods on thin mild steel won't work well.
>I used to use SS rods to weld spring steel that I was using to make cutting dies for cutting leather parts on a hydraulic press. The lower temrerature of the SS rods prevented the high carbon steel from becoming burnt out and brittle, thus cracking around the weld. Sometimes you caqn use SS rods to weld cast iron provided it is of the malleable variety.
