Table Top Thickness
Jeffrey D. Rose
>I am not near any of my design resources and trying to figure out how thick most people make their kitchen table tops?
TIA
Jeff in Iowa.
Table Top Thickness
Jeffrey D. Rose
TIA
Jeff in Iowa.
Thicker the stronger; thinner the lighter
Forrest Addy
>Thicker the stronger; thinner the lighter but 3/4" seems to be about right for most dining and furniture tables.
I prefer 7/8" because my eye is jaded with ubiquity of 3/4". 7/8 seems to me so robust a thinkness without seeming clunky or heavy. It's a perception thing I couldn't help mentioning.
Re: Thicker the stronger; thinner the lighter
>Good Afternoon Jeffrey,
I think 7/8" looks better, and I do agree with Forrest. An extra 1/8" thickness over 3/4" allows more choices and room for edge treatments. Besides, a 7/8" board is quicker to thickness plane from 4/4 stock. I shoot for 7/8" thickness in my cabinet/furniture tops also.
George
7/8" is a man's man thickness to be sure
Mark McC
depends on the design of the table
Bill Tindall, E.TN
>and the size of the table and probably other factors I can't think of. In most cases anything less than 7/8 to 1" looks skimpy in most designs (5/4 lumber), but for a Trestle table more than an inch would be necessary.
Bottom line, accurately draw a side profile to scale and see how different thickness look.
Re: depends on the design of the table
Bill White
>Built a farmhouse style table several yrs. back. 1 1/4" top w/ heavy looking legs. Came out well.
Bill
I Once Had A Neighbor
>Whose daughter resembled that table's top and legs. I think her name was Clementine.
George
I made a pine kitchen table for our use
Don henthorn
>with 1 1/2" thick top. It had thick legs so it looked OK.
Was this neighbor...
>...a miner? 49'er?
Re: Table Top Thickness
DB
>If you want a stronger table top without it looking to thick just taper the outside bottom face back about 2-3" down to about 7/8". Could also taper the top face too.
It all depends on what look you want. Where I used to work we would routinely make the edge 1-1/2" thick by building up the edge of the sheet good with a 3/4" build up of particle board and band the edge with veneer.
I bet her Daddy was.
Gary Evans Tallassee, TN
