Cyclone delivered PIC *LINK*
Bartee (metro Atlanta)
>My Grizzly G0441 cyclone was delivered today. It had tobe delivered to the foot of my driveway and I had to haul it to the basement in pieces. A little extra effort today in the 99 degree heat. But it was certainly worth it.
That's the filter on the top, the rest of the cyclone is in the bottom box. Some very good packing!!!
Here is one Picture.. the rest are in a Web Album ( link below )
Web Album
Re: Cyclone delivered PIC *LINK*
Re: I have that unit
Larry Clinton At Frankfort (Central)., Indiana
>Man is it heavy! I wall mounted mine - That puts the blower assembly about 7 ~ 8 foot up on the wall. I had a big chunk of sycamore, 'bout 2 1/2 X 12 wide, I cut about 4' long and lagged to the 2 X 6's in the wall. My son and a friend mounted the unit. They did some sweating and groaning getting it in place. I installed mine using pvc piping. I did make an 8" X 6" X 6" "Y" connector for the inlet. I couldn't find one in S & D, went to several plumbing houses and all the borgs. The cheapest I found was over $150.00 for all the pieces needed to do the transition. Ended up with less than $25 by making my own (did have a short 8" piece of Pvc pipe given to me free). I really like the unit, had it in a year or two now. I had a problem with the start switch and Capacitors - Grizzly did a fine job of sending the replacement parts. (I sure didn't want to remove the blower / motor assembly and return it - we fixed it on the wall). It does an excellent job keeping the dust and chips clear on my 20" planer with about 35 foot of 6" pvc and 10' of 6" flex in the line. (even with a second gate open). I can run 3 smaller gates (4") at the same time with little or no degradation in performance. I really like the remote - It is line of sight so be sure to position the control box high enough and in a position that you can see from all your machines. It is noisy - but all the units I have seen are about the same. I am sure you will be pleased - let us know how you like it after you have it in place.
Bartee ( Metro Atlanta )
>Larry, thanks for the update.
I am going to wall mount mine also, but I am building a very small room to surround it and the air compressor.
I am looking and thinking on how to do it.
Good info on the length of you 6" runs. Mine will be about the same.
I am planning going from 8" to 6" right off the unit and then stay 6" to all machines. Where I need to I will go down to 4" for specific machines.
I Like . . .
Scott Greaves in Blackfoot Idaho
>I like how they disguised it to look like cardboard boxes! ;-)
I'll be waiting to hear how it works for you. I really need to get something in my shop.
Scott.
