Info on a Griz TS
Bill White
>Anyone have the Grizzley G0444Z TS? Would like to see opions on same.
Thanks,
Bill
Info on a Griz TS
Bill White
Thanks,
Bill
Re: Info on a Griz TS *LINK*
knotscott
>I don't own it but am fairly familiar with it and have used some saws that are very similar.
The G0444Z is a traditional contractor saw format. The saw itself is nearly identical to the GI 50-175, Bridgewood, Woodtek, and many others. The bolts-ons and accessories are what's different, and even many of those are similar. The fence is a Biese homeshop clone and is very good IMHO. The motor is a full 2hp, but note that it draws ~ 24 amps and should be run on a standard 20 amp 110v circuit...it really requires 220v line or a 30 amp 110v circuit. IMHO, it's very nice contractor saw, but poses all of the same issues as any traditional contractor saw with an outboard motor.
There are alot of good hybrids with enclosed motors available now, and they offer several advantages over a contractor saw with literally no downside....smaller footprint, better DC, shorter drive belt, more mass, etc. Griz's hybrid is the G0478...Shop Fox has a version in white. Jet offers the Workshop, Proshop, and Supersaw. Delta has the 36-715, 716, and 717...same saw, different fences. GI has the 50-220C, 50-220C M-1, and 50-220C-LM-1...same saw, different fences.....Sunhill offers a model that's very similar to the 50-220C. Craftsman has the 22114 and 22124 with cabinet mounted trunnions... Steel City offers the similar 35601, 35606, and 35610....same saw, different fences, and one with a 3hp option. DeWalt has the older DW746. Hitachi has a C10FL. It's worth some research before plunking down over $500 for a nearly obsolete design. There's just no advantage to getting a saw with an outboard motor unless you need to remove it often. Food for thought...
epinions.com/22124 review
Typo correction...
Planky
>...Sorry, I made a significant typo that I don't know how to edit out.
"but note that it draws ~ 24 amps and should be run on a standard 20 amp 110v circuit..."
Correction...it should "NOT" be run on a standard 20 amp 110v circuit, or you'll risk tripping the breaker frequently.
Typo correction...
knotscott
