drillling end grain question
Bill Tindall, E.TN
>I need to drill a long hole in end grain (bed bolt) and it needs to drill straight. What is best- brad point or drill pointed for metal?
Re: drillling end grain question
Brad point ground on aaircraft drill
Forrest Addy
>Brad point ground on aaircraft drill. You know, he kind wih a long straight shank and a short length of flutes. These drills are very stiff but you have to peck the hole in short increments.
If you have to be well aligned to a certain point at the exit, drill from both ends to meet in the middle.
Re: brad point and these are excellent *LINK*
Dave Mount
>I own and am very impressed with these bits from Lee Valley -- well worth the money (no affiliation).
Best,
Dave
Lee Valley brad point bits
Drillling end grain hint
Lee Schierer - McKean, PA
>Since you will most likely not have a drill press to perform this drilling and you certainly don't want to go out the side wall, make a wooden drill guide by drilling through a short piece of similar scrap material on your drill preess and then gluing that guide piece to another longer board making an L shaped arrrangement. You can clamp the drill guide against the end of the piece to be drilled and the longer board will run parallel to the side of the piece being drilled. This will get your hole started straight and then you can remove it to get the hole to the full depth once you are in pretty deep.
Lee
Ron Hildreth, Alta, Iowa
>Hi, Bill
How deep will your hole have to be, and what diameter? You mentioned a bed bolt, so maybe 3/8ths or so? I "drilled" a hole through the center of a stair baluster to make the pot and pan hanger for our kitchen. I wanted to lag screw it into the ceiling joist, fearful that my wife would overload it. To do this, I sawed it in half on the table saw, run the two halves through the router table using a core box bit, then glued the two halves back together again. Worked great, and the joint is invisible.
Sorry for the lousy photo, as I was having camera problems then.
Ron in Iowa
Al Stokka - Cambridge, Iowa
>Bill,
I would be inclined to drill the hole a deep as possible with a forstner bit. Then, to drill deeper (forstner bits are rather short) switch to a twist drill. Once the hole is started with the forstner, the twist drill will run true.
Al
>Bill, I did it the "other" way also. I laminated the bed rails out of two thicknesses. Used a core box bit and routed the two halves of the holes in each piece. At time for for glue up, I oiled the threads inside the nut to keep the glue out and wrapped the shaft of the bolt in plastic like a plastic bag. (Glue won't stick to poly) The nuts and bolts served as alignment devices for the two halves. Later I removed the bolts and pulled the poly out of the holes. Actually ran a drill in and out to finish cleaning them out.
A suggestion. Make the hole somewhat over sized and leave a small amount of wiggle room for the nut. I found that half inch holes for the 3/8" bolts worked well and allowed the nut and bolt to "find" each other. Seemed to have no effect on the strength of the joint. Mine were rock solid, not bragging, just impressed with a really solid connection. I put an over sized washer under the nut and head of the bolt. I think it is the bearing surface on the grain that provides the rock solid support without the bolt compressing or deforming the wood.
Another suggestion: Turn the set up around and put the nut in the post and bolts in the rails. It makes for an "invisible" connection with no hole in the post or cover for the hole. If you are interested let me know and I will send more details.
Couple ideas for you...
>First, I second Lee Scheirer's suggestion about a guide fixture for your long bit. That alone should do the trick. But, I have not had much luck with brad point bits tracking a straight hole in endgrain. If the grain is leading any particular way, the point tends to follow it. (This is just my anecdotal experience; I have not done any controlled testing of this theory.)
Years ago, when we were building driveway gates (among other things), we needed to have dead straight holes through 16/4 mahogany rails so we could mount SS strap hinges accurately. I came up with a mod for a standard aircraft-type bit (118� tip grind) that tracks beautifully. What it is is about a 60� notch, about 1/8" across, cut into the tip of a standard twist drill. As it drills, the notch createa a tiny cone in the center of the hole that guides the drill very accurately, or that's my theory at least.
This photo shows me using my little perpendicular drilling rig with one of these modified bits. In this case, I was drilling across the grain, but the bit works just as well into endgrain. Might be worth a little experimenting.
Ellis Walentine, Host
PS, this is a rare photo of the inside of my old shop. The oval stuff on the back bench is parts for a cheval mirror project I was building for issue #31 of American Woodworker, back in '93 or so. Tempus fugit.
Here's a shot of the drill bit mod
>My good 3/8" aircraft bit with the notch I mentioned didn't survive, so today I quickly ground a similar profile on a junk 1/2" bit I had lying around. The trick is to get the notch centered across the center web of the bit. If it is off center, the drill will want to jump a little when it enters the wood, and it won't track as well. If I had a triangular diamond file, I'd probably use that instead of a grinding wheel.
Hope this helps you visualize what I'm talking about.
PaulA
>My limited experience is that sharp split point drill bits, which typically having 135 degree points, work best for this operation. Next come simple twist bits and third in effectiveness in staying on target are the brad point bits. It really depends on the wood, however, with the most difficult being those woods that have rather different hardness between the early and late woods. Doug. Fir and some of the hard pines are a challenge.
The previous post about starting with a forstner bit seems like a good idea thought I have not tried it.
Paul
