REAL MILK PAINT
Magnetic catch question.
>I am making a piece of furniture with small doors (12' x 12' +/-) I have hidden a rare earth magnet in the top edge of each door. Was planing to hide a matching magnet in the top rail and have a completely invisible "catch".
It occurs to me that I could just counter bore the screws that will hole the top on and insert the magnet in the counter bore. Maybe glue it to the screw head.
Does anyone know if sticking on the head of the screw will reduce the magnetism, making the catch less effective? Would this be more or less than an 1/8" of wood between?
Re: Magnetic catch question.
Lee Schierer - McKean, PA
>The screw will act as a duct for the magnetic flux, but will not decrease the magnetism. The wood you planned to use to hide the magnets will be more of a concern. The thicker the wood, the farther the magnets will be apart and the lower the attraction which may affect the ability of the magnets to keep the doors closed. I would suggest you place material of the same type and total thickness plus any air gap between the magnets before you assemble it into your project to determine if you set up will actually work.
Lee
>Lee Valley sells some metal housings that go around the magnet. They have a screw hole for mounting. This makes the magnet stronger. They are listed with their rare earth magnets.
Re: Holy cow!
Al Stokka - Cambridge, Iowa
>Barry,
If 12' x 12' +/- is what you call small, I wanna see pictures of your big stuff!
Sorry, I'm weak and couldn't resist,
Al
