Painting basement floor with epoxy paint question
wilbur
>I was thinking of painting the floor in my basement workshop with white epoxy paint, mainly to help increase ambient light, but also because the floor looks like crap compared to the walls that have a new paint (actually, Drylok) job.
There's one spot in the floor that a little water seeps up through, but only after a humungous rain. We're talking about a once every 2 years sort of rain.
Am I asking for trouble?
Re: Painting basement floor with epoxy paint question
Dan Manturi
>Well, when I did my basement, I drylocked the walls and just used a pigmented stain (Behr) on the floor. Had the color matched at Home Creepo to the wallpaper I used down there (I did put studs and sheetrock up after I Drylocked the walls). VERY cheap, brightened the basement, kept down any cement erosion / dust, and did not create any kind of surface that would be a problem later. Epoxy is great stuff, but I do not know if it would tend to bubble or even be an issue if you were going to do something else down the road.
It has been there since 1991, and still looks decent, and cleans reasonably well.
Good luck.
Dan
Bart Goldberg
Bart Goldberg
>I don't think so. Assuming that the epoxy paint isn't going to get wet prior to curing, once cured, it will be waterproof.
Bart
Mike Farinella
>If you decide to install the epoxy in your basement, consider using breathing apparatus and vent the basement all you can. That stuff stinks to high heaven.
>I have been blessed with two dry basement floors.
Do a moisture test on your slab. Put down some pieces of polyethylene in the suspicious spots. Put something (like an old plate or pie plate with the rim side down) down on the polyethylene and put a little weight on the plate (a couple of lbs). Wait a week or so. Look at the underside of the polyethylene after that. If you have a fair bit of moisture, you may have problems.
If you don't have problems, go for the epoxy paint.
If you do have a lot of moisture, consider a concrete "stain" that would let the water through.
Our old lab had a lot of water coming through the slab. We put down a hi-tech paint system and it bubbled up. We had it scraped off and a stain put down.
Just my $0.02.
Hi Jack!
Ernie Miller
>I was just ask by a friend here at work about painting a basement flooe she has epoxy down and it is cumming up after only two years she wants to redo it and ask if the old needed to come off. I said yes cause the old will continue to flake off taking the new with I figures that is was not acid etched or properly preped. so what is the easiest way to remove the old? I will have her do the pie plate trick in an open place that has pealed off. about 50% gone after two years!
Some Tips
Rick Christopherson
>I have epoxied my garage floor (spancrete) and plan on doing the basement shop later this year. First off, do not waste your money on the cheap epoxy they sell at home centers. This will not last very long, and the difference in price for a good epoxy is not worth the risk. I bought my epoxy at a commercial paint store, and they could colorize it to my liking.
Another issue I had not considered until reading an unrelated discussion is that when you acid etch the floor (required step) make sure you either remove all tools, or find some way to protect them and ventilate the shop while the acid is present. The vapors from the acid may cause your tools to rust. I don't know if this will happen or not, but now that the idea came up, I want to plan ahead for it.
Confirmation
PaulA
>I can confirm, unfortunately, that acid vapor will rust your tools. I had been using some hydrochloric acid and half filled a yogurt-size container with the acid. I finished my work, but left the container open on the bench near my drill press and many bits. I returned days later to find rust over the column of the DP, on the quill, on all my forstner bits and numerous other items in the vicinity. This was the first time I ever had rust problems in my shop.
Paul
Yes, But...
Rick Christopherson
>This is exactly the same type of story I read elsewhere that led me to say what I wrote above, however, what I do not know is whether the lowered concentrations used during floor etching will have the same results.
Nevertheless, thanks for the reply because this is the type of information that people need to know before proceeding.
Re: Yes, But...
PaulA
>My personal opinion is that if one follows recommended procedures of good ventilation when etching the floor then it should not be a problem. In particular, if the etching is done with open windows AND a fan I would feel safe doing it. Without ventilation in a basement shop , I would remove all tools prior to etching.
Concentration of the vapor and time to react are the two principal parameters. At low concentrations the problem is much reduced. Tools 1 meter away from my container of acid were unaffected in my basement shop while those at half that distance and closer were very affected. I have my garage floor epoxy covered and I etched it prior to application and noticed no problem with tool rust. The etching was done with the garage door open.
Paul
Ventilation
wilbur
>Thanks for the tips. I was planning on ventilating well anyway because my wife has a bionic nose, but I appreciate the heads up about the acid fumes and rust.
As far as ventilation goes, I've got 4 words: Bilco door/big fans. Hopefully that will do the trick.
Re: Some Tips
Woodenfish
>I would consider using vinyl composition tiles instead of the possibilities of having epoxy coatings peeling, especially on a basement floor which would seem likely.
Larry Clinton At Frankfort (Central)., Indiana
>I used the Rustoleum garage floor epoxy in my shop. I did not have the option of removing my tools (didn't want to "roll" a 20" planer, unisaw, 8" joiner - etc. on a gravel driveway). We moved the equipment to one side of the shop, and cleaned the (year old) concrete floor with a off brand citrus cleaner and then with the solution in the Rustoleum kit. After drying and coating that area with epoxy, we waited a couple days and moved all the equipment to the coated area and repeated the process on the other side. The cleaner furnished in the kit did appear to slightly etch the surface. I had no problems with any rust on any of my tools. We did ventilate well during the cleaning process - left the 8' X 9' door open. The epoxy has been down a couple years with NO pealing or bubbles. I have been very happy with the results. My shop floor is pretty dry so moisture is not an issue - can't comment on that aspect. But I will say in my situation, the Rustoleum has held up to the heavy equipment rollers as well as any we used in the factory where I worked before retiring. We used the highest grade epoxy there after sandblasting the surface to etch, we coated over 100,000 sq./ft. - the Rustoleum seems to be at least as good.
